orionexplorer Posted April 7, 2009 Report Posted April 7, 2009 what exactly does amp hours mean? and how does a single wire alternator work? i just dont get how it works with just a positive output and no ground or does it have a ground and im juss readin wrong or something. 6 dc level 3 12's digital designs Z1A pioneer h/u 4 sets of rockford 6.5's crunch 1600.4 Mechman 270a alt kinetik hc2400 (soon to be xs power d3100) xs power 3400 (under the hood) lots of 1/0
troy Posted April 7, 2009 Report Posted April 7, 2009 amp hours is how long it was played. i may be wrong but a ingle wire alt is a alt that is grounded through the chasis. retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Kapetol T Posted April 8, 2009 Report Posted April 8, 2009 1 amp hour is the ability to sustain one amp of current for one hour or 2 amps for half an hour or 4 amps for 15 min etc.... I assume you were talking about a battery?
Neo_frog Posted April 8, 2009 Report Posted April 8, 2009 amp hours is how long it was played. i may be wrong but a ingle wire alt is a alt that is grounded through the chasis. WTF? Amp hours or Ah is the maximum sustained amperage drawn from a fully charged battery over a certain time period to a point where the battery is at 100% depth of discharge. In other words, dead. A 200Ah (20 hr rate) battery can sustain a 10-Amp draw for 20 hours before being completely dead. 10 Amps X 20 hours = 200Ah. The concept isn't always consistent in the specs because as the load increases, the capacity of the battery decreases. It makes for a nonlinear discharge if you were to see it on a graph. A single wire alt only has a + wire going to the battery (and possible splits to go elsewhere). It's grounded to the engine through the alternator housing, and your engine is grounded to your chassis. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
orionexplorer Posted April 8, 2009 Author Report Posted April 8, 2009 thanks neo frog 6 dc level 3 12's digital designs Z1A pioneer h/u 4 sets of rockford 6.5's crunch 1600.4 Mechman 270a alt kinetik hc2400 (soon to be xs power d3100) xs power 3400 (under the hood) lots of 1/0
