Need Another Amp For Tweets
CHINO11550
I have a Zapco amp running 8 tweets @ 1ohm but the amp is a 2ohm so when i play music loud for a long period of time the amp goes into protect sometimes. I need a amp that can give me the same power @ 1ohm if there is any
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
Rockford Fosgate do a couple of 1 ohm stable full range amps.
Also the DLS Ultimate A3, a very very VERY nice amp.
10.x volts fo' life!
could you not get a 4 channel amp and run 2 sets per channel?
R.I.P!
(Nov-29-2009)
92 explorer
current build
Ive never heard of DLS but the specs seem very good
MLA module 15+volts
Team Bass Hz
MLA module 15+volts
Team Bass Hz
I dont want to re-wire anything.
MLA module 15+volts
Team Bass Hz
