I just purchased a DD Z1 amp first generation, that has been repaired before breaking by Ohio center for amp repair. What kind of reliablity can I expect from their work? I have reciept as proof of repair work and what Scott at Ohio amp repair replaced. I will post pics once it arrives if there's any interest. I paid $575, it is in mint condition (missing two speaker terminal screws). He had two and he was selling because he got two Cactus 7kw to replace to run his two 12" DD Z woofers. He sent pics as proof. He might even be on this forum, not sure though. All I want to know is how reliable this amp will be. Can I really expect 5000W+ plus without it going into protect? Will have an MLA module shortly for 15-15.5 volts.
Edited by cc_audio
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
That amp isn't know for reliability, sadly. I suggest you don't run it under 1 ohm and keep the gains down.
lP lR O Jl lE C T - C G 6
DD 9512G - DD M2A - DDA W - DD S4A - ALPINE W505 - IMPRINT
Guest reestblazer
x2. I know many friends up here in MD that are DD reps and they go through them like candy!
Could you be specific on what the problems were with these amps? Was it one recurring problem that needed to be fixed because the amp did have something replaced. Output drive I think but not sure. Its a gorgous amp and i can't imagine too many other problems since the Z1 and Z1a have the same board. You guys are scaring me here. :blink: Give me some more details about problems since the amp is already on the way.
It's all gone!
The Celica Build
Feedback
the DD Z1 was known to blow daily
the Z1A is the reliable daily one they improved
R.I.P!
(Nov-29-2009)
92 explorer
current build
It arrived. Thought I'd throw some pictures of the amp and the repair reciept. Also, what I plan to do to it.
The driver board was repaired. Was that the only problem with these amps?
Gonna add some plexi to show off these beautiful internals.
Got his for $3 on ebay brand new. Should keep the amp ice cold for me.
It's all gone!
The Celica Build
Feedback
ya definatly got a rep for smoking but I had one that we removed the rear and stuck fans on it, its wired at 1 ohm with 3 2150s on it and a powermaster alt. its i think around 2 years running now with no probs
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
I have two of them. One went up in smoke about 3 weeks after I got it (blew a fet) and then the other the power supply went out in it (turns on and off ever 5 seconds or so)
They put out massive power, but aren't to reliable. =[
