To figure out the amp draw just do 1400 watts divided by 12 volts so 1400/12 = 116.66 amps.
just do the same thing for 14 volts or whatever your volt is.
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
does the voltage drop that low right away or is it after awhile it will get that low?
Yea right away it starts to drop i wonder if my battery up front is shot because its dated like 10/07 haha
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
for me right away at high bass notes. sorry for the tread jack but im stuck too with this problem
Yea mine doesnt drop that low on high bass notes only when i get closer to tuning
Edited by Moore941
1 Dc lvl5 18
shootin for 145+ :)
flashlight i would get the mla and that should help you out for moore i would start with replacing the starting batt and see what it does i am assuming you have a 1/0 run to the batt in the back and its grounded in the trunk or to the frame?
Roseville, CA
Yea its all 1/0 knu wire from the batt to batt and alt to batt im gonna cheack all my grounds tomorow and see if that helps any, and if not im gonna throw a red top i have in my race car and see if that helps any.
1 Dc lvl5 18
shootin for 145+ :)
that would be a good thing to check with the grounds and redtop but do you have anything else thats not stock thats hooked up to the batts besides the 1400 watt amp?
Roseville, CA
Well i had my kicker kx550.3 hooked up to it but it blew last week so now i have a dual 560.2 on it
1 Dc lvl5 18
shootin for 145+ :)
