does any one know what the rms and peak on this sub is? i bought one from a guy in my class for 30 bucks and i dont want to hook it up and feed it to much power and blow it. also what size box should i make for it?
i found the sub is 425 watts rms in a .88cu. ft. sealed box. it says its not recommended for a ported box. what is a good 425 watt rms 8ohm amp?
sb 12d? is that one of them old school round ones??
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Rms wattage on that sub is only around 300wrms, 350wrms tops.
Other specs.
Size 12"
Peak Power Handling 600 Watt
Frequency Response 20 Hz - 100 Hz
Sensitivity 87.7 dB
Enclosure Ported
Top Mounting Depth 5.63 In.
Mounting Diameter / Length 11.13 In.
yea there the old school round ones.
Ah ok, I thought so... i used to have some of those back in the day.
how did u like them? did they hit good?
