Moore941 Posted April 21, 2009 Report Share Posted April 21, 2009 Looking for a alternator for my 2000 dodge durango with the 5.9L possibly dual setup with stock and aftermarket if possible, ill be running from 8000-10000 watts in my next system so i need a setup that will suffice for a daily driver, let me know looking forward to doing some business in the near future with u. Quote 2000 White Dodge Durango 5.9L Flowmaster 40 Series through 2 1/2" with and open cat. 1 Dc lvl5 18 4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2 Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire shootin for 145+ Link to comment Share on other sites More sharing options...
MECHMAN Posted April 21, 2009 Report Share Posted April 21, 2009 Looking for a alternator for my 2000 dodge durango with the 5.9L possibly dual setup with stock and aftermarket if possible, ill be running from 8000-10000 watts in my next system so i need a setup that will suffice for a daily driver, let me know looking forward to doing some business in the near future with u. I offer a single large case conversion unit. It does 250 amps with 150+ amps at idle. I would also do the in-cab adjustable voltage control option so you can bump the voltage up for better amp efficiency under load. The whole pre-wired kit is $599 and is a direct bolt in. Thanks Matt Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
Moore941 Posted April 21, 2009 Author Report Share Posted April 21, 2009 Thanks man ill be in contact Quote 2000 White Dodge Durango 5.9L Flowmaster 40 Series through 2 1/2" with and open cat. 1 Dc lvl5 18 4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2 Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire shootin for 145+ Link to comment Share on other sites More sharing options...
