I am puttin 3 12s in my wifes explorer they are 4ohm svc and I have two 2ohm stable 1200 watt amps how and can I wire up both amps to the subs I would like to bridge the amps to try to get pretty decent sound from this bty its all sony ftl but she likes it ftw
Edited by svman
You can't get a 2 ohm load. You can get a 1.34 or a 12.
You can however use two of them to end up with a 2 ohm load.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
would this work with a 2ohm stable amp?
You could try it and hope for enough rise.
Are you going sealed or ported?
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
you cannot wire 2 amps to 3 subs. not for a sony amp, no way in hell.
try ported for those subs, they should sound alright.
No, that won't work.
You could run 1 amp on 2 of the subs (so it sees 2 ohms) and the other on 1 of the subs then gain-match them so the subs are all seeing the same power.
If you wire it like above... I'm not 100% sure what would happen but it wouldn't be pleasant, I bet.
10.x volts fo' life!
buy one more sub..
Paralell 2 together
Paralell the other 2
then series em for a final load of 4 ohms
EDIT: Didnt see that you had two amps
Just run 2 off one amp save the other tamp ans sub for a rainy day
Edited by smokeumtires
Dude, don't wire that way veryyyyyyyyyy bad things will happen. All the magic smoke will come out. You're not goin to get 3 of those subs on 2 amps unless 2 on 1 then 1 on 1, Heh Heh 2 on 1.
Team Soundstream
Team Optima
Team HK
2 Soundstream SPLX-152HX
2 Soundtsream TRX2000D
1 Soundstream RUB4.600
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream S-Cell400
1 Soundstream Power Plant
1 Soundstream BX-15
1 VMAX CT1900
2 Optima Yellow Top D34/78
1 Kenwood KDC-X493
  • Who's Online   0 Members, 0 Anonymous, 3955 Guests (See full list)
