How? Port Displacement....and Box Design...
Rogers
UPDATE!... well i got the enclosure assembled... all that is left is cutting the holes out for the woofers, ports, and terminal cup... i plan on getting these holes cut today.... then it will be ready for carpet!
here it is!
Posted Image
some how i lost 1/8" in width so it will kick my tuning frequency up to around 35.5... i figure it was just due to the blade width while i was cutting... no big deal its still within my range of tuning frequency so im not going to mess with it...
Posted Image
comparing the 3" tubing to the 4" tubing
Posted Image
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Looks good man, I still remember the first box... And then what it is now haha
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
Lawl here is the first box
Before I got ahold of it
Posted Image
After I was done with it
Posted Image
Car
1996 Sable LS
My Build
Truck
Truck Build
damn nave!!!! you did a number on it for sure! well here is another update.... i got the holes for the subs cut out, aswell as the ports installed... just need to install a terminal cup and carpet it and it will be ready to boom!!!
Posted Image
Posted Image
3 Kinetik Hc2000's
Dual 200amp alts.
Looks GREAT! Any updates? Played it yet?
Just a FYI for next time you build: Make a small area where the ports will be installed double thickness. Cut the OD pipe size in the inner piece, and the ID pipe size in the outer piece. you can then run a roundover bit on the outer piece to get a small flare. It is just enough to really cut down on noise from the sharp edge of the port.
Like I did these boxes:
Posted Image
Brian
Current system:
Previous systems:
  • 6 years later...
hey i been looking at 4) 12 inch sub boxs. i just put together one that is a sealed and divide in 4s. its 36w x 30d x 13h i dont know what it sound like yet, i have been wanting a 28 to 35 hz box. its a 05 chevy malibu car trunk space is 39w x 36d x 17h. have a boss bv7330 320 watt head unit , spl spq-20 pwm 18dB parametric EQ , boss 3000 watt AP 2 channel amp , 2 power caps 1 fad and 2 fad , and 4) new pyle power black PLPW12D 12 inch 3200 watt rms , 6400 watt max power , dual 4 ohm impedance , 60oz magnet , 2.0 in voice coil , SPL 90 dB...... im looking for loud deep bass for competion ... trying to decide which way to go with the sealed one i have now or with the one you been talking bout but 36w x 30d x 13h and 4 pvc 3inch x 9inch long.... any suggestions?????????????
Besides the fact that this thread is 6 years old, make your own new thread, and ditch that shit equipment if you "want to compete" as you say. Although I suspect troll. No one is dumb enough to believe in all of that garbage at once.
  • 4 years later...
This is an old thread, but I had to say I totally know what this guy is going through.  When I look at numbers my mind goes BLANK with a side of tension headache.  Ask me to combine multiple sets of numbers to come up with some other magic number and I might just implode.
The only way i'm getting anything done is if someone does the math for me, produces the cut-sheet, and then I can build the box.
I'm good at many things, numbers will just never happen for me though.
most people say you need 12-16 square inches of port area, what I am trying to figure out is how they arrive at that number. So for my given speaker, I can calculat what cross sectional area I need. Here everyone says your need 12-16 inches per cubic foot, but others say that cross sectional area is only determined by your speaker. so which is it, anyone know?
  • Who's Online   0 Members, 0 Anonymous, 731 Guests (See full list)
