How? Port Displacement....and Box Design...
Rogers
its boggling my mind.... how do you take into account the port displacement in an enclousure when you dont even know how big your port is supposed to be.... so say for instance... in my case.... im doing an enclosure for 4 10" alpine type s's and i need 1 cube net per sub. each sub has a driver displacement of.05cuft, so that would be .2cubes in driver displacement....
i want to do 4 3" round ports..... the box will be subs up ports back...... my max dimensions are.... 23"long X 37"wide X 15"tall....
i want to tune between 35 and 40 hz... i listen to mainly heavy metal and occasional bass testers....
can anybody shed some light on my situation???? this box thing has been stressing me out all night!
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
well, it sucks, but everytime you get a port drawn up, you have to put it into the total box equation.... The box gross volume always stays the same, but the net volume will change with every port configuration you try + different tuning.... Trial and error at it's best.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
The length of your vent (Lv) = 1.463 x 10(to the 7th Power) x Port Radius in Inches ® / Tuned Resonance (Fb) x Volume of Enclosure in Cubic Inches (Vb). Or something like that.
Using basic math, you can tune your box to whatever frequency you want (very easily too since you're using round ports).
for every cubic foot of space in your box you will need 14-16 square inches of port, so if you box is lets say 5 cubic feet then you will need (5x16=80/ 5x14=70, 70-80 square inches). To get 70-80 square inches of port area you will need three 6" ports, or six 4" ports, or a slot port measuring 20"x4", etc.
Always make the enclosure about 1.5 cubic feet larger than it should be, so in your case, design a box that is 5.5 cubic feet. That will allow room for port displacement and sub woofer displacement. If its driving you this nuts building a box for your woofers then you are honestly worrying too much about it, build it close enough to specs and it will sound good.
Oh and sketchup is your friend when building and testing out sub boxes.
Posted Image
Posted Image
Ports are 8.6" long tuned to 35hz
Box is 5.71 cubic feet net
port displacement is 1.67 cubic feet for all 4 ports combined
sub displacement is .2 cubic feet
~3.84 cubic feet after displacement.
The higher you tune the more cubic feet you will end up with
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
this crap is so confusing!!!! im not good with programs or math... but im good with my hands...lol.... if someone is bored.... design me a box.... if you can take all my info that i gave in my first post and design it... i can adjust it for bracing...
ive actually built a pretty sweet box but its too tall for the car.... after i got it in i noticed that the cones will hit the roof of the trunk... it was a big fail!
i just took alpines specs for a vented box right out of the manual and did a 4 in 1 enclosure
Posted Image
3 Kinetik Hc2000's
Dual 200amp alts.
Posted Image
Posted Image
hell yeah.... that is a BIG help.... thats awsome! atleast i have some numbers.... i think i can take it from here..... Thank you so much!
do you think i should do some bracing or is it necessary.... the type s's arent super powerfull but i am going to be running 1000wrms through them....
3 Kinetik Hc2000's
Dual 200amp alts.
yes you should add vertical supports inside the box to help with flexing, also u might want do a double baffle where the subs mount.
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
how do you suggest that i compensate for the loss of volume due to bracing... just change port length or make the box a tad bigger or what????
would a 21.5 by 6 verticle brace be sufficient enough?
3 Kinetik Hc2000's
Dual 200amp alts.
save the money on ur system and buy a better ride man...just IMOO
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
Why all the guessing and approximations?
The easy way -
You know what you want your net volume to be.
You should know the driver displacement.
You know how much port area you need.
Calculate the port length based on area (you should know approximate H x W too for a slot port).
You now know port displacement.
Gross volume = net volume + driver displacement + port displacement.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
