eliassami5 Posted April 24, 2009 Report Posted April 24, 2009 Why all the guessing and approximations? The easy way - You know what you want your net volume to be. You should know the driver displacement. You know how much port area you need. Calculate the port length based on area (you should know approximate H x W too for a slot port). You now know port displacement. Gross volume = net volume + driver displacement + port displacement. the problem is that he wants 4 cubic feet (minus the port and sub disp.) but when he designs his box and subtracts out the port and sub displacement it dosent come out right. Its a game of guess and check, its not like hes building a wall which dosent involve all of this designing and re-designing to fit in a particular tight space. 91' Jeep Cherokee - The Heep Just Empty Every Pocket 96' Volvo 960 - The B◘x [sPL_4_U] HiFonics - Alpine Pioneer - Clarion Infinity - Kicker KnuKonceptz
bkolfo4 Posted April 24, 2009 Report Posted April 24, 2009 I don't get your calculations above. I know this is off: "port displacement is 1.67 cubic feet for all 4 ports combined" ?? Even with an OD of 3.5", that is (1.75^2 x pi) x 8" long x 4 ports = 308 / 1728 = .18 ft^3 displacement. He needs 4 ft net driver displacement is 0.2 ft He wants (4) 3" ports. they need to be 13.36" long for a 35 Hz tune (not 8.6" long). We will call it 13", since up to 40 Hz is acceptable to him. Assume they are made of PVC, so the displacement (subtract .75" where they go through the wood) will be about 0.27 ft for the ports Gross volume needs to be 4.47 ft^3 or 7730 in^3. We know max dimensions are 23"long X 37"wide X 15"tall. Assume 15" tall, that is 13.5 internal. 7730 / 13.5 = 572.5 Need a length x width that equals 572.5. (4) 10's won't fit across 37", so go with 23" deep (21.5" internal). 572.5 / 21.5 ~ 26.75 Box can be 15" tall x 28.25" wide x 23" deep. (4) 3" ports 13" long. That is 4 ft^3 tuned to 35 Hz. Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Rogers Posted April 24, 2009 Author Report Posted April 24, 2009 save the money on ur system and buy a better ride man...just IMOO what does it matter.... its a car with a big trunk and a decently strong electrical system.... the car was given to me=free... and i have all the equipment... i just need a box... and thats all i asked for... im not even sure you know what kind of car it is.... i would prefer this to NOT be a usless post thread.....thank you! http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
Rogers Posted April 24, 2009 Author Report Posted April 24, 2009 I don't get your calculations above. I know this is off: "port displacement is 1.67 cubic feet for all 4 ports combined" ?? Even with an OD of 3.5", that is (1.75^2 x pi) x 8" long x 4 ports = 308 / 1728 = .18 ft^3 displacement. He needs 4 ft net driver displacement is 0.2 ft He wants (4) 3" ports. they need to be 13.36" long for a 35 Hz tune (not 8.6" long). We will call it 13", since up to 40 Hz is acceptable to him. Assume they are made of PVC, so the displacement (subtract .75" where they go through the wood) will be about 0.27 ft for the ports Gross volume needs to be 4.47 ft^3 or 7730 in^3. We know max dimensions are 23"long X 37"wide X 15"tall. Assume 15" tall, that is 13.5 internal. 7730 / 13.5 = 572.5 Need a length x width that equals 572.5. (4) 10's won't fit across 37", so go with 23" deep (21.5" internal). 572.5 / 21.5 ~ 26.75 Box can be 15" tall x 28.25" wide x 23" deep. (4) 3" ports 13" long. That is 4 ft^3 tuned to 35 Hz. Brian wow confusion...lol.... lets just clear up some stuff... the ports are 3"id and 3.25" od...... im going to go get a fresh sheet of mdf today so i hope we can get this cleared up.... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
Nightshade Posted April 24, 2009 Report Posted April 24, 2009 Someone said that you need 14-16 sqin per cuft for a box and that's true when you are using a slot port. Since you are using aero ports you can get away with much less port area. You'd be fine to do around 9-12 sqin per cuft when using an aero instead of trying to get 14-16 with them. Unless you aren't using aeros and just some round pvc, then I would do a little more port area per cuft since the ports won't have the flares on them. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
bkolfo4 Posted April 24, 2009 Report Posted April 24, 2009 (3) 4" ports would be more port area. If you bought aero ports from PE, it would work even better. http://www.parts-express.com/pe/showdetl.c...tnumber=268-352 I would also double the top baffle. Need 4.2 ft^3 + port displacement. (3) 4" ports need to be 17" long (that is how long aeros come - tunes around 36-37 Hz in this case) Port displacement is around 0.4 ft^3, so you need 4.6 ft^3 gross. That is 7948.8 in^3 With 23 deep x 15 tall external, 7948.8 / (21.5 x 12.75) = 29 internal width. Box will be 15" tall x 23 deep x 30.5 wide. 1.5" top baffle, 3/4" sides and bottom. 4 ft^3 NET volume, (3) 4" ports tuned to 36-37 Hz. If you are not going to buy aeros, it can be adjusted to lower the tuning to 35 Hz if you want. Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Rogers Posted April 25, 2009 Author Report Posted April 25, 2009 (3) 4" ports would be more port area. If you bought aero ports from PE, it would work even better. http://www.parts-express.com/pe/showdetl.c...tnumber=268-352 I would also double the top baffle. Need 4.2 ft^3 + port displacement. (3) 4" ports need to be 17" long (that is how long aeros come - tunes around 36-37 Hz in this case) Port displacement is around 0.4 ft^3, so you need 4.6 ft^3 gross. That is 7948.8 in^3 With 23 deep x 15 tall external, 7948.8 / (21.5 x 12.75) = 29 internal width. Box will be 15" tall x 23 deep x 30.5 wide. 1.5" top baffle, 3/4" sides and bottom. 4 ft^3 NET volume, (3) 4" ports tuned to 36-37 Hz. If you are not going to buy aeros, it can be adjusted to lower the tuning to 35 Hz if you want. Brian ok so i bought a sheet of mdf today i doubt its enough but i can always get more... id rather not buy aeros... i just bought 5 feet of 3"schedule40 pvc today... ok so let me get this understood.... 15"tall x 23"deep x 30.5"wide.... double baffle..... ok i got that.... so for the ports really i could go anywhere from 9.71 to 13.36.... according to the port calcs that 40 and 35hz so anywhere inbetween would be a good correct???? since im doubleing up the baffle is it necessary to do anymore bracing???? im thinkin i proble wont..... man i hope i dont fuck this up......lol.... so for board placement... should i just cut the bottom piece and put the walls on top of it... and then put the baffles ontop of them or should the top of the baffle be flush with the walls? ive seen it done both ways.... i just didnt know if you adjusted the enclosure for flush baffle displacement..... let me know man! http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
Rogers Posted April 25, 2009 Author Report Posted April 25, 2009 mabe you just need to draw it out with crayons for me.... or sketchup, whatever your best with....lol http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
bkolfo4 Posted April 25, 2009 Report Posted April 25, 2009 I cut my bottom and and top baffles full size and sandwich the walls between them. Port lengths are correct for (4) 3" ports. (4) 3" ports are less volume than (3) 4" ports, so you can make the box 29.25" wide if you want. Not going to make much difference. Sounds good, and I am sure it will turn out GREAT. Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Rogers Posted April 25, 2009 Author Report Posted April 25, 2009 I cut my bottom and and top baffles full size and sandwich the walls between them. Port lengths are correct for (4) 3" ports. (4) 3" ports are less volume than (3) 4" ports, so you can make the box 29.25" wide if you want. Not going to make much difference. Sounds good, and I am sure it will turn out GREAT. Brian so then i could just even it out and do 30 wide just to make it easier.... as long as i keep the ports between say 9.5 and 13.5 inches.... not going to make much difference... right... it sounds like it will be in the tuning range of what i want it to be.... i appreciat your time man....... that goes to everyone, thanks..... except the asshat that told me to get a different car... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
