Benji0687 Posted May 7, 2009 Report Posted May 7, 2009 you're only required to have two working brake lights on the rear of your vehicle in ohio...i removed my 3rd brake light on my caprice and havent had a single problem with it. really, if it looks like it was never there, they will never know. and even still, youre fine as long as you have two functional brake lights. 1989 Chevy Caprice Classic350ci V8 High Performance JVC Arsenal HU JL XR series components Infinity Reference 6x9s Pioneer Premier 4-Channel Clarion 2-Channel Rockford Fosgate Series 1 2-Channel Fusion 2000.1D MTX Crossover RF, Knu, Kicker, and Monster wiring NVX VCW 12in. Sub **Won on here from the Sonic contest!** *Build log coming soon!* Starting all over pretty much which the gear listed...lost almost everything I had, including my life. Never take life and what's in it for granted.
Pioneer~Saturn Posted May 7, 2009 Author Report Posted May 7, 2009 Thanks guys, and yea...i was pretty sure you were just required 2 working brake lights...and it looks like it was never there Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 8, 2009 Author Report Posted May 8, 2009 Alright, got a decent amount done today but not a ton.. Marked a board to go on the side..the line is to be cut to mate with the angled piece (you'll see) Screwed a board to it to guide the router to cut the line.. Bam.. Mock-up..you can see the part of the wood that kind of got chipped-off and there's a slight gap, no worries...its going to be sealed and fiberglassed over The other end of the angled piece will need holes drilled with the jig so I can attach the other side's side piece to it.. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 8, 2009 Author Report Posted May 8, 2009 The foam's gunna getcha! More tomorrow Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
jzizzo57 Posted May 8, 2009 Report Posted May 8, 2009 do you not use mdf because your going to fiberglass the whole inside of the box and it therefore doesnt matter?
Pioneer~Saturn Posted May 8, 2009 Author Report Posted May 8, 2009 do you not use mdf because your going to fiberglass the whole inside of the box and it therefore doesnt matter? No, mdf is cheaper and easier to work with imo...but definitely not lighter...I dont really want to upgrade/fix my suspension just yet so I went with birch to save quite a bit on weight. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
audiofanaticz Posted May 8, 2009 Report Posted May 8, 2009 This is looking like a killa build thread! Have you got to listen to the omegas yet? I heard some last sunday.
Pioneer~Saturn Posted May 8, 2009 Author Report Posted May 8, 2009 Thanks Im pretty excited to see the outcome But sadly I havent heard them Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
uhoh_45 Posted May 8, 2009 Report Posted May 8, 2009 so whens the estimated time of being complete cause i cant wait to see this thing finished R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Pioneer~Saturn Posted May 8, 2009 Author Report Posted May 8, 2009 so whens the estimated time of being complete cause i cant wait to see this thing finished Well there's a 2x comp locally the 17th and come hell or high-water this will be done for that...so by the 16th I would say this will pretty much have to be completed...but I could see it being completed before-hand pretty easily (atleast to a point that I could put the subs in and listen to it). But it shouldnt be much longer untill I start the port, which is really the last big part of the build...might take two days to do. After it's all made the real challenge will be to start sealing everything from the trunk and making it look good too...might be a while for all of that to completely be done. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
