got this install at a local shop and the other day when me and my boii kentb was lookin at da demensions for my new box we saw da power cable dat goes to my amp and they put a 200 fuse!! im running a hifonics colossus! he agreed wit me that i need a bigger fuse but how big do i go??? 250 or 300??? im running 0gauge wire!! and does it matter wat kind of power cable i have???
05 Ford F150- STOLEN!!!!4 AA Havocs 15s in a WALL4 Hifonics 2006ds1 kinetik 1800 in front4 kinetik 2400s n bakHifonics MaxxlinkAudiocontrol Epicenter2 runs 1/0 guage kicker hyperflexall other wires r knukonceptzTraded In05 Chevy SilveradoAscendant Audio 16 12s2 Mechman 320s1 Kinetik 1800 in front8 Kinetik 2400s n back4 2200 Audioques ampsLots of 0 gaugePioneer DeckAudio Control preampHifonics Maxxlink
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Audiocontrol Epicenter indash
All Rockford 1/0 & every cable in there
Jl audio xd 600/6
Rockford Fosgates Mids & highs
Built By Audiotistics!
what is the total amps of the fuses in the amp?
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
i got a 250 ran from my front battery to my rear, but i unno bout useing one that big goin to the amp, it will take a shit tone more than 200amps to blow one of those fuses, my friend had a run of 0guage in her alero with a 150amp fuse and when they took her system out the power wire was still hooked up n my buddy found that out, n he said when he looked under the hood the fuses was bright red but wasnt blown, so ied be careful runnin that much unless its less than how many amps ur amp's fuseing is worth,
ied run fuses to my amps from rear battery but i only have about 12-15'' of wire comein from it so fusing isn't all that necessary to me, as long as my batterys are fused thats all im worried about
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
You would be surprised... rock the 200 until it blows, then go to a 250A.
coo i can do dat cause i was lookin at da manual!! YES I SAID DA MANUAL!! lol and dat shit says
Route a 2 gauge power cable directly to the vehicle battery with an in-line 300 amp fuse.
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Jl audio xd 600/6
if it calls for a 300A fuse then why use a 200A fuse?
well dats wat they installed at da shop u would think they know best but i guess not!!!
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Jl audio xd 600/6
might of been what they had on hand. never know bc some shops were im at dont handle 300amp fuses, you got to order it.
but if amp calls for 300amp, then run the 300amp fuse
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
the 200 is fine for a 1600 watt amp(you should have learned by now that RMS matters, max is a bad joke)
they know what they are doing, that fuse should basically last you forever.
Team DC
I say use the 200 until it blows. Unless my understanding of fuses is wrong (and though it's possible, I doubt it) it can't hurt anything to have a fuse that will blow sooner. But one that is rated for more can.
EDIT: I can't spell tonight. lol
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
