themoney8 Posted April 30, 2009 Report Posted April 30, 2009 ok im having one of the most common and most stress full problems... engine noise..i have celession 6.5 for the doorz titanium bullet tweeters for each door but i dont have them on my head unit is a pioneer f90 bt and i have it to an hifoniz zeus ive grounded everything RCA i changed the main head units ground ive grounded the amp with 0guage and i still here engine noise.. when i turn the hazards on i hear the clicking noise threw the speakers i dont know what else to do... SOME ONE HELPPPPPP!!!!!!
Boon Posted April 30, 2009 Report Posted April 30, 2009 I still say it's the Pioneer problem. Unless you do the fusible link properly it'll probably still have noise... 10.x volts fo' life!
Krice420 Posted May 1, 2009 Report Posted May 1, 2009 do you by chance have you rcas running near your power wire cuz this will let in some engine noise as well. 2 18'' fi btls fully loaded 2 sundown saz 3000d 1 iraggi 200 amp alt 3 powermaster 3100d series batts 11.75 cuft wall after displacement tuned to 31.08 hz
kirill007 Posted May 1, 2009 Report Posted May 1, 2009 Maybe you're ground wire is too long. Thinking is the root of all problems... You ALWAYS get what you pay for.
wierdguy75 Posted May 1, 2009 Report Posted May 1, 2009 Had the same problem installing a deck into my boys neon, regrounded the amps, radio, and caps. Ended up he went to discount and got a ground loop isolator. Worked like a charm. It was only like $20.
