Setting Amp With Multimeter?
is there any GOOD video tutorials that show how to set the amp with a multimeter? I don't have access to an o-scope so don't mention it lol.
I saw the basics of doing it, but it was just for the gain/level and i need that plus sub sonic, bass boost, and lpf.
ALSO, is a dual 2 ohm Fi BL 2 or 4 ohms? Or how many ohms is the frickin sub lol?
Thanks.
Good guide there.
Remember that you cannot measure impedance with a multimeter - ohms are the unit used for both resistance and impedance, which are two different things and people tend to get that confused. Resistance is simply that, whereas impedance is a function of resistance, capacitance and inductance. The speaker's voice coil is effectively a variable iron cored inductor. Therefore, impedance can only be measured at a given frequency and averaged, hence the term nominal impedance. Impedance changes over the frequency range of a sub greatly, and it is greatly affected by the tuning frequency of the port.
A good example of this is if you build a ported box tuned for 60hz, put a suitably tough driver in it and plug it into the mains. Impedance rises sufficiently high - to around 30-50 ohms for an 8 ohm driver - to prevent current from being so great as to cause voice coil heating.
Nasty subs to drive - like some of the Infinity line - are rated at 4 ohms nominal but will drop to 1 ohm when driven below Fs. Those are very hard on your amp.
i thought that was just the ohm load on the amp?
exactly. a dual 2 ohm sub is just that. dual 2 ohms. different ohm ratings on subs allow for various wiring configurations for the amp. if you want a 1 ohm load, you get a dual 2 ohm sub and wire in parallel. get 2 dual 4 ohm subs and wire them both in parallel for a 1 ohm load on the amp. if you wanted a 2 ohm load on the amp, get a dual 1 ohm sub and wire in series, or a dual 4 ohm sub in parallel.
I don't think you will see a sub's impedance fall below the DC resistance. The DCR of a 4 ohm sub should be around 3.2 ohms
Brian
Current system:
Previous systems:
I measure "resistance" with my multimeter. Just measure the resistance of each coil (as directed in the instruction manuals that came with it) while the power is off (obviously), if anything is funky then that's bad. Wire it up, and the wires should measure the proper resistance
  • Who's Online   1 Member, 0 Anonymous, 1200 Guests (See full list)
