Bdsync And Bd1000.1 + Bd500.1?
Sick916
Can i use my BDSync cable to link my BD1000.1 and BD500.1 or do they need to match as in both being bd1000s. They are the 2002 model i believe. Link to pic posted below.
http://i115.photobucket.com/albums/n282/va...sc/DSC00152.jpg
Yes i realized it is a 550X in the pic, but they look exactly the same.
1996 Camaro RS
Rockford Fosgate BD1000.1
Rockford Fosgate 400a4 Old Skool
2x 12" TSW3001-D4 Pioneer Subs
Pioneer deh-p980bt
Yellow Top Primary Battery
1.5 Diesel Audio Cap<Its just there to impress the females with shiny things ;)
Kinetik HC800
No don't do that. Those amps need to be the exact same in order to use the bd sync cable to link them together. You will mess something up if you try it with a 1000.1 and a 500.1
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
x2,x3,x4.
You have to use 2 of the same model to beable to BDsync the 2001,2002,and 2003 BD amps.
All amps have to beable to output the same amount of power or you most likely will blow them up.
How ever you can use the same amps from different years to BDsync together.
So you can BDsync a 2001 BD1000.1 with a 2003 1001BD or use the 2002 1000BD.
Same goes for the BD1500.1,1500BD,and 1501BD and the BD500.1 with a 501BD or 500BD, but you never want to BDsync these amps if they don't put out the same amount of power.
That means no BDsyncing any of the BD500.1s with any of the BD1000.1s or BD1500.1s.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
