LiL PiNoY Posted May 3, 2009 Report Posted May 3, 2009 car starts up fine, battery up front is steady at 12.7 volts when car is off. i know my alternator is probably busted but will i make it to the shop without having it die on me on the road. shop is about a hour away.
sully Posted May 3, 2009 Report Posted May 3, 2009 anything is possible, i wouldn't try it though. If you turn everything electrical off (ie: lights, a/c, radio) it might make it there if the battery is fully charged and in good condition. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
Soulman07 Posted May 3, 2009 Report Posted May 3, 2009 I drove for around an hour on an HC1800 when my battery died... I got back home later on that evening and the battery usually rests at around 12.9 it was around 12.2 hour rate on cell batteries are insane! I wouldnt't try it on an acid battery though..... 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex
LiL PiNoY Posted May 3, 2009 Author Report Posted May 3, 2009 i hope so man i have two kinetiks 1 hc 2000 and 1 hc 2400
Soulman07 Posted May 3, 2009 Report Posted May 3, 2009 i hope so man i have two kinetiks 1 hc 2000 and 1 hc 2400 I had around a 1 hour commute total for around 52 miles. Kill all of your electronics like he said and you'll be fine. During the past hurricane.. eduardo I think it was... we were without power for around 3 days. I pulled the hc800 out of the trunk and my farenheit din and a few 6x9s wired them all up in my living room so we can watch movies and listen to the radio. Radio was on around the clock except for 3-4 hours a night when we slept... Power came back on and I tested voltage with a multimeter! It didn't drop but .3 over that time frame. I know the HU don't pull many as many amps as a cars accessories would. The reserve capacity on these things are nuts though. I've left my amps on accidently when I forgot to hit the kill switch NUMEROUS times for a day and a half and the car would start back up. You should be fine for an hour homie. 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex
moh.vze.com Posted May 5, 2009 Report Posted May 5, 2009 Pu tang ani moh DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
LiL PiNoY Posted May 5, 2009 Author Report Posted May 5, 2009 ok got a call from the shop and they said that the bracket holding the alternator snapped would this be why the alternator stop turning or they just trying to get more money
Moore941 Posted May 5, 2009 Report Posted May 5, 2009 well if the bracket was broke it could have caused the alternator to not be in its original resting place but if thats the case the water pump or power steering would have been off due to the belt not turning because the tension was gone due to the lack of alternator, what kinda car? nvm stupid edit: i see it says belt not turning now haha yea that deff could be the issue haha 2000 White Dodge Durango 5.9L Flowmaster 40 Series through 2 1/2" with and open cat. 1 Dc lvl5 18 4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2 Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire shootin for 145+
