this is what i came up with
box height - 14
Width - 17
Length - 35
Port height 12.5
Width - 3.25
Length - 29
2.40 cft3 @ 36.48 hz, port area 40.63in2
L shape port.
any good or no?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
anyone?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
looks good on paper.
U sure the woofer will clear?
yup. my box right now is 17 inches deep, dub baffled, so sitting up 1.5" subtrack .75 for bottom of box, subtract 12.75 leaves me with 4.25 inches from bottom of sub to the back of the box. also ray you said sub passenger side, port drivers side, does it matter if the box is small and they are just behind the seat? or will a bigger box help? because i could get more cubic feet out of it and go with same dimensions but longer box. if not ill stick with what i wrote a few posts above.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
drew it up and here is my cut out list
top (where sub is mounted and is ported) 31.75 x 14
bottom - 35 x 14
sides - 15.5 x 35
ends - 12.5 x 15.5
port A piece - 9.25 x 12.5
port B piece - 19.75 x 12.5
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
bottom - 35 x 14
sides - 15.5 x 35
ends - 12.5 x 15.5
p.s how many watts can i feed this xxx? im getting a sundown saz-3000D now. so ill have plenty of power.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
what ohm coils do you have?
i would feed it 2000-2500 rms CLEAN CLEAN watts.
I think the woofer just isnt even moving on that power
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
2k to 2500 is good on it
yea i figured about 2500. thanks. also, for this box and the port, what should i do, 45 the corner, or try to cut a piece of hard hard cardboard cylinder into 4's and use those in a corner with a bit of fiberglass, or would it be fine just to 45?
also its a dual 2 ohm. wired into 1 ohm
Edited by Hostility
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
  • Who's Online   0 Members, 0 Anonymous, 1832 Guests (See full list)
