i would agree with the 2 20 amp fuses and doubt that it will even put out much over 400 watts. with that into consideration that may not blow the sub but if the amp was up to par with its specs it would not be a good idea at all and it would MOST LIKELY blow the sub.
now that were on those terms i think he should get a different amp. One with more power and that is ABOVE its specs...such as a T3002 or a T5002.
NoFearX18 said:
trainman0978 said:
i would also HIGHLY recommend a T10001bd that way for now he can wire it to 2 ohm mono and get around 600-800 RMS and if he ever wanted to uprade and have 2 subs he can get another T1 dual 4 and wire it to 1 ohm mono giving him around 1300-1500 RMS.
great for his application if he plans to upgrade
NoFearX18 said:
trainman0978 said:
If the amp put out what it said it does I would have never told him to do that.... and yes I totally agree with you that he needs a new amp the T3002 or a T5002 would both be good choices for him with that sub.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
aight i got you....i understand your side but you do got my side where if the amp was up to its rated specs?
NoFearX18 said:
trainman0978 said:
Oh yes, if it were a true 1100 watt amp I would not tell him to do that, because it would cause thermal overload and sub would be toast!
I see we posted at the sametime last post.... you are also correct about the 1000, if he plans on getting another sub he wouldn't have to buy anything else cause his amp would be great for 2 of those bad boys!
Subs: 4 Fi BL 18's
true dat!!!
NoFearX18 said:
trainman0978 said:
yea im definitly upgradeing to more than i 15 and im going to buy the t10001bd for my t1 when i get the other sub..ima go get another battery and use the one amp i have for a break in for my subs till i get the other fosgate
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
yea it should sound real real real good. ima put up some video and stuff when i get some more batteries for my camera
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
  • Who's Online   0 Members, 0 Anonymous, 960 Guests (See full list)
