Celica Build Big Sub Little Car
looks great so far.... did the other amp come in yet? hows that sub coming along? updates :)
Full eclipse system is next on list.. soon to gut and redo the honda as new project/rolling buissness card :)
i miss the sound of those old school strokers on beast amps :(
Nope, still have no amp. I'm really anxious to get it too. I do have some pics of the sub but I'm not allowed to post them. Ken says they're top secret :ph34r: so you'll just have to wait. :P
Here's a vid of my temp system though.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
  • 1 month later...
Finally got the ambition to get out and start getting everything nice and pretty for the new sub. I didn't realize just how big my little T2 really is. I know you guys like pics so I took a couple.
Started removing all signal wires so nothing would interfere.
Got the die grinder out and removed some of the old body filler that I mixed too hot. What a pain in the ass!
Somehow I left the end of the shop-vac in the box. What an interesting find.
Taking the fuses out, just in case.
It's all gone!
The Celica Build
Feedback
Like everything else I've done to this car, I just kind of make it up as I go along. Using my tape skills I got the curves and contours I wanted. Be sure to do two layers of tape, makes removal much easier and the heat of the resin won't warp the tape. Really helps maintain shape.
Thats me!
Started with one layer across, then two, then five and 8 layers of glass in some spots (like the corners)
When I took the trunk lid off, I had to find the wire connector to the third brake light. Some butchering of the dynamat was necessary.
And then I began to fill the bracing with some Great Stuff.
It's all gone!
The Celica Build
Feedback
The trim panel is almost cured and ready to pull.
Since my car is decomissioned, figured I'd slap the ol' power supply on there and see if I can't bring my float voltage back up to 13.4 volts.
Very carefully, with thin drywall knife and finger, I pulled the piece out. Took about 20 min to get it out.
Also made some foam art.
Peeled all the tape off the trim panel.
Thats a lot of tape!
The panel drops in perfectly. No binds at all, no interference just perfect. Now I just need to trim it, level it and bondo it.
Here's a little trick for you. Before laying down fiberglass, draw on the tape with permanent marker where you plan on cutting the panel. The permanent marker line on the tape will transfer to the fiberglass and now I have a line to cut along. Saves a lot of time.
It's all gone!
The Celica Build
Feedback
UPDATE UPDATE UPDATE!!!
Here's some teaser pics of the GZ sub.
Forevrbumpn is the shit! Need a woofer done? Talk to Ken, he will hook you up.
haha... thanks for the props
I think I will just dome it and ship it. I need to get those leads up and away from that aluminum spider clamp too
specs look great for what you will be doing with it, lets see if it can handle that 7000 Atomic!
