yes and most likely some magic smoke.
1st  SMD "System of the Month" Feb. 2007
Zapco Studio 500 (2)
Zapco Studio 300X
Zapco Studio 204 (2)
(2) FI 12ssd's w/ copper coils
DLS Iridium Tweeters
DLS UR2.5 MidRange
FI. N.7 Midbass
JL Audio TWK 88
Mechman 370A Elite Alternator
honestly... if its a ported enclosure... at the tune frequency the resistance comes closest to dcr (resitance measured on a multimeter)... which is when it would most likely go into protect or produce magic smoke...
u could have quite a bit or impedance rise tho... so say ur box is tuned to 30hz... dont play below 40hz (just an example) and the resitance the amp sees while producing that note might be closer to 2ohms this it will be ok... but drop a note towards the tune frequency and POOF... fried amp
and yes, it will get hott fast since its drawing more current at the lower resistance and unable to disipate it
Edited by decafcappucino
1 of 2 things...
Either it'll think it's a short and sit there in protect OR it'll blow the fck up the first time a good bass note hits. Thermal runaway and avalanche current, mmmmmm FET smoke....
10.x volts fo' life!
If you wanna run it at 1/2 ohm. make sure when you start it is a slow volume roll up. dont just play your system right off of the bat, it will just go into protect. I'm builng my burp box now for my 2 ohm stetsom to be ran at 1/2 ohm.
You need alot of battery, and make sure your voltage does not make the amp go into protect, very very bad for the sub.
Edited by Kian
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
yea itl heat up like a muh fugga if it doent go into protect first....nawty nawty :D
Eclipse cd7000
if you do it for burps only you should be ok but daily it would kill the amp just think of it like running a 300 shot of nitrous for a short burst it is ok but continuosly it would blow the motor.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
Pretty much.
Just make sure you keep your electrical above 12.4 volts when doing so.
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
  • Who's Online   0 Members, 0 Anonymous, 725 Guests (See full list)
