viperd911 Posted May 12, 2009 Report Share Posted May 12, 2009 just a question will it heat up quickly or what? Quote Link to comment Share on other sites More sharing options...
BAGGEDBIRDS.com Posted May 12, 2009 Report Share Posted May 12, 2009 yes and most likely some magic smoke. Quote 1st SMD "System of the Month" Feb. 2007 Zapco Studio 500 (2) Zapco Studio 300X Zapco Studio 204 (2) (2) FI 12ssd's w/ copper coils DLS Iridium Tweeters DLS UR2.5 MidRange FI. N.7 Midbass JL Audio TWK 88 Mechman 370A Elite Alternator Link to comment Share on other sites More sharing options...
Rose-Villian Posted May 12, 2009 Report Share Posted May 12, 2009 And That thing they call protect will turn on lol Quote WWW.OSGINDUSTRIES.COM I LOVE HATER'S Link to comment Share on other sites More sharing options...
Decaf Posted May 12, 2009 Report Share Posted May 12, 2009 (edited) honestly... if its a ported enclosure... at the tune frequency the resistance comes closest to dcr (resitance measured on a multimeter)... which is when it would most likely go into protect or produce magic smoke... u could have quite a bit or impedance rise tho... so say ur box is tuned to 30hz... dont play below 40hz (just an example) and the resitance the amp sees while producing that note might be closer to 2ohms this it will be ok... but drop a note towards the tune frequency and POOF... fried amp and yes, it will get hott fast since its drawing more current at the lower resistance and unable to disipate it Edited May 12, 2009 by decafcappucino Quote Link to comment Share on other sites More sharing options...
Boon Posted May 12, 2009 Report Share Posted May 12, 2009 1 of 2 things... Either it'll think it's a short and sit there in protect OR it'll blow the fck up the first time a good bass note hits. Thermal runaway and avalanche current, mmmmmm FET smoke.... Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
Darksideofsound Posted May 12, 2009 Report Share Posted May 12, 2009 clip, clip, smoke.....clip, clip, smoke.......nothing, nothing, smoke....nothing, nothing, smoke.....fire truck, fire truck, smoke........ Quote Link to comment Share on other sites More sharing options...
Kian Posted May 12, 2009 Report Share Posted May 12, 2009 (edited) If you wanna run it at 1/2 ohm. make sure when you start it is a slow volume roll up. dont just play your system right off of the bat, it will just go into protect. I'm builng my burp box now for my 2 ohm stetsom to be ran at 1/2 ohm. You need alot of battery, and make sure your voltage does not make the amp go into protect, very very bad for the sub. Edited May 12, 2009 by Kian Quote --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped Link to comment Share on other sites More sharing options...
finkster Posted May 12, 2009 Report Share Posted May 12, 2009 yea itl heat up like a muh fugga if it doent go into protect first....nawty nawty Quote DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living Link to comment Share on other sites More sharing options...
oldschool Posted May 12, 2009 Report Share Posted May 12, 2009 if you do it for burps only you should be ok but daily it would kill the amp just think of it like running a 300 shot of nitrous for a short burst it is ok but continuosly it would blow the motor. Quote TEAM GROUNDPOUNDERS INC. 156.5 OUT THE TRUNK OF A 95 CADDY W/1 SUB & 2AMPs score done on a termlab mic in the kick on the dash sealed was 154 Link to comment Share on other sites More sharing options...
Kian Posted May 12, 2009 Report Share Posted May 12, 2009 if you do it for burps only you should be ok but daily it would kill the amp just think of it like running a 300 shot of nitrous for a short burst it is ok but continuosly it would blow the motor. Pretty much. Just make sure you keep your electrical above 12.4 volts when doing so. Quote --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped Link to comment Share on other sites More sharing options...
