bobonit Posted May 15, 2009 Report Posted May 15, 2009 I want to make 2 buss bars, one for ground and one for positive. I'd like to mount them to opposite sides of the same piece of wood. No pieces of metal will touch, so would this be ok? 97 Maxima SE Bunch of shit going in, check out the build Build Log
Pioneer~Saturn Posted May 15, 2009 Report Posted May 15, 2009 Yep, should be just dandy Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
bobonit Posted May 15, 2009 Author Report Posted May 15, 2009 Cool, that will make wiring it much cleaner. 97 Maxima SE Bunch of shit going in, check out the build Build Log
Boon Posted May 16, 2009 Report Posted May 16, 2009 Cool, that will make wiring it much cleaner. Just be reeeeeal careful that your screws don't accidently meet in the middle of the wood 10.x volts fo' life!
BigJohnny Posted May 16, 2009 Report Posted May 16, 2009 make sure they won't ever get wet either. wood will conduct electricity if its wet or too moist.
