Pre Amp Outs?
so my current head unit only has 2v pre amp outs and ive seen some nice pioneers with the 4v pre amp outputs and supposedly this will make the subs sound clearer or sound better? would this be a good reason to upgrade the H/U?
Yes you will want atleast 4v pre outs they do send a cleaner signal and are less stressful on your amps the higher the better.
Eclipse
Hifonics
Alpine
Kinetik
Optima
Excessive Amperage alt
Yes you will want atleast 4v pre outs they do send a cleaner signal and are less stressful on your amps the hight the better.
thanks man prolly go with a pioneer deck i have a kenwood have had it for like 2 years and has barely any subwoofer settings so great reason to upgrade the system a little bit
line driver FTMFW!
go off functions of the head unit and the look or whatever then get a line driver.
if it has everything you want go for the pioneer.
Wouldnt be thehoe92 without teh purple
Most modern amps can make full power off as little as ~0.2v input. Preout voltage is critical when it's being split a lot or noise reduction is paramount.
10.x volts fo' life!
Pioneer pre-outs<Alipne pre-outs<Eclipse pre-outs
Do your research. Some advertise 4V but it sure doesn't sound like it.
lP lR O Jl lE C T - C G 6
DD 9512G - DD M2A - DDA W - DD S4A - ALPINE W505 - IMPRINT
  • Who's Online   0 Members, 0 Anonymous, 867 Guests (See full list)
