Ford Explorer Box Build 2 Cvx 15's
Not really new to car audio, but this is probably my first major stab at making a custom box. The purpose of this build was to give my CVX's (wish they were better, but a gift is a gift) some more ft3, however I still want space to put things in the back as well as have access to the spare. Box's dimensions give ~7.8ft3 after displacement, tuned to 31-32Hz. If you notice I angled the back of the box to contour the seats and to try and get as much space as I can in the trunk.
Equipped with some cheap tools and a flat surface, I got to work. Let me know what you think, critiques always appreciated.
Posted Image
Posted Image
Posted Image
Just want to point out that, Yes, I actually cut all that damn birch with that lousy 5.25" and a wobbly glass patio table. Needless to say all my cuts are still accurate.
Posted Image
Posted Image
Its hard to appreciate, but the back panel is bent to shit. Even though the joints are set perfectly at 90 degrees, the sides are bowed out 2-3".
Posted Image
Posted Image
Posted Image
After a little bracing and some clamps the back sat nice and straight.
Posted Image
Posted Image
Posted Image
Notice the angled back.
Posted Image
45's to button it up.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Now time to brace it up with some 1" dowel rods.
Posted Image
Posted Image
Posted Image
Love the Jasper, just watch out cause its easy to divot the last little cut
Posted Image
Posted Image
Double baffled and ready to rock.
Posted Image
box looks solid congrats
R.I.P!
(Nov-29-2009)
92 explorer
current build
A little messy, but at least all the cuts are straight.
Posted Image
Posted Image
Posted Image
Posted Image
A little stain and poly left around from a furniture repair.
Posted Image
Time to wrap it up. I was aiming to somewhat match the interior colors of the truck.
Set the saw really shallow and cut the parameter of the box, so I could tuck the vinyl edges into. The design changed a couple times, but I think it turned out pretty good.
Posted Image
Posted Image
Posted Image
Posted Image
Wasn't really digging the big white box, so I changed it up a little.
Let me know what you think.
Posted Image
Went a little too close to the edge there
Posted Image
Posted Image
Obviously my vinyl edge jointing is a little rusty, but I think you can tell which ones I did first.
Posted Image
Posted Image
Posted Image
Here it is in the trunk. I know the vinyl doesn't match, but hey its close enough.
Posted Image
Fits snug up against the back seats.
Posted Image
