Can I run two dual 2 ohm's to get an amp load on 1 ohm without bridging the two channels of the Sundown SAZ-2000?
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
i believe the amp is internally bridged. you will need a pair of d1 or d4 subs to get a 1 ohm load. if you parallel the 2 coils and run each to its own channel the amp will actually see .5 ohm
DC.jpgDC POWER
just go here
http://www.the12volt.com/caraudio/woofer_c...s.asp?Q=&I=
and put in how many subs, what the ohm config they are, and it will show you what you can wire it to
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
x2. u probably could run the sundown @ .5 ohm daily without problems though, ask jacob aka "sundownz" on here to make sure.
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
x3... not under warranty but with box rise and all the amp prolly wont see .5ohm
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
