Hes only got the one amp, the front stage is alphasonik component setup with the tweeters mounted in the dash.
Looks like your right about the model of the amp, it is a 1000hca, and ya it is a 2channel. I should edit that, lol
mmmmm.. bass.RD Audio
Wired at 1.3ohms on the amp...YOU WILL NOT see ANYWHERE near that 450watts per woofer.....after box rise/imp rise your going to be over 2ohm probably closer to 4ohm in all honesty. Get a DMM and AC clamp and get actual power, before you tell people this amp is rated at 3000watts...that doesnt mean the amp does that power....
ied run 3 subs per channel @ 1.5 ohm n with box rise it will be around 2ohm, might help out the power to sub ratio, and help em not run out of phase as much, in first vid it looked like middle subs wasnt moveing n one on each corner was movein like hell, but unless other channel is messed up run 3 subs on each channel,
or u can wire each sub 2ohm n it will give u 1.5 on each channel might work better
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
What is the box tuning? And turn it around as others have mentioned with the port at the rear of the vehicle.
The woofers might suck all the air out your lungs
(if you stand too close)
When the monster hums
