Thanks guys! Awesome advice from everyone.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
if it's the power akoustic screen thats in your sig, just take the brake wire and hook it up to the ground wire. it'll will work perfect. i have installed several of those screens in my customers cars and i do it every time
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
power acoustik, just take the light green wire (should be labeled parking brake wire, either with a tag or in the manual, sometimes was a pink wire, most had light green) and ground it...either to your black line, chassis, or the unit itself even
pioneer non gps can be grounded with a switch, as can clarion and alpine...pioneer nav's a pin has to be moved and grounded from the normal harness to the rca harness in a specific blank spot, avic 411 has info on it...older n'series had a sticker you had to peel up and flick a switch underneath, z1/2 needed a special update disk to disable it.
jensen is that code mentioned before
phase linear is the same code (both made by audiovox)
kenwood i think is just grounding the light green
Team DC
my alpine needs a sequence to "turn" the E-break on
just bought/installed a TR7 and dont gotta worry bout shit
R.I.P!
(Nov-29-2009)
92 explorer
current build
Mine was the light pink e brake wire and all I had to do was ground it, Thanks everybody!
  • Who's Online   0 Members, 0 Anonymous, 1717 Guests (See full list)
