i just got an amp its a Lanzer Vibe 430 and i hooked it up to my AudioBahn AW 1006T Flame Q Car subwoofer 900w
both coils are hooked up
i had a 250w amp before this one and it hit no problem with both coils connected.
all of my knobs on this amp are turned to minimum
basicly when i put my volume at 35% on my deck it hits for 3 seconds then my sub flexes wierdly and then the protect light turns on. i checked all the cables and there fine i just replace the remote wire with an 18 gage.
any suggestions would be awsome! will post pics soon.
Sicc 2 Sicc
SMD FOR LIFE
What head unit?
Check and make sure you have a good ground (contact bare metal on the frame)
Double, even triple check that the wires are all run correctly and there are no shorts (I know from experience that sometimes in the excitement of getting stuff together it is easy to oops some wiring)
Otherwise, maybe the amp has an issue.
Too many projects, too little time...
I FOUND THE PROBLEM!
its a lanzar :lol:
EDIT: sound like a power problem. what gauge wire u runnin?
Edited by BanginOnABudget
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
check ur ohm load maybe u have it wired lower then what the amp is rated for
x2 that was my first thought.... i immagine that amp is only like 4ohm stable... just guessing though...
hey dont be hating on his lanzar.... i had a vibe240 and it was a solid amp...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
I like lanzar, just not so much on the vibe series, except the Vibe1200D. I can almost bet it's an impedence issue.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
How did you hook it up? One coil to each bridged channel pair?
no i got a wireing diagram heres the link http://www.the12volt.com/caraudio/woofer_c...sp?Q=1&I=22 i did the first option plus the speaker is runnin of 18 gage wires which i think is the problem. i need an opinion but you had an awsome idea about One coil to each bridged channel pair.
Sicc 2 Sicc
SMD FOR LIFE
oh thanks for the defense homie anyways my sub wired like a one ohm i wired it like this http://www.the12volt.com/caraudio/woofer_c...sp?Q=1&I=22 the first opyion i think thats the problem if im wrong plus the speaker is running 18 gauge wires
Sicc 2 Sicc
SMD FOR LIFE
  • Who's Online   0 Members, 0 Anonymous, 1048 Guests (See full list)
