Yeah your high-bass will seriously lack impact tuning that low.
If you're gonna do it, low-pass it at 63hz or lower and you better have the midbass from hell.
10.x volts fo' life!
/thread
I hardly ever heard of a song that hits 20hz. Really.
Tuning around 28hz is be the lowest i would go.
'99 Civic hatch
18" AA Chaos - 7cuft @ 34hz - 114sq in. port
Mac Audio Fearless ~ 1000wrms @ 2 Ohms
Videos:
Youtube
I just built a box that is 29 hz. The box I had before was 35-36 hz and I am debating if I should put it back in. My 29 hz box does't pick up highs nearly as much. It's a tossup. Lows are nice but you to have some serious power to really get loooow.
2008 Chevy Impala (undercover cop style)
Setup in the makings
Tuning isn't everything....my old box was tuned at 31hz played 30hz-55hz extremely loud.....my new box is tuned at 38hz and it plays ~20hz and up to 60hz very loud.....with this box I can play with the whales....not many people believe that I am tuned at 38hz.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
30hz is all you need.
x2
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
The last few boxes I have built I've ended up doing a free-space tuning of 40hz or higher. You put them in a car and load the subs and ports off the air in the car and a couple of surfaces and they'll play way below 'tuning' without a hitch and you get way better output because you have the freedom to use larger ports.
My DD9515 in a 3 cube box tuned to 42hz played 29hz very very loud, was just in a small car and loaded well off the roof...
