Can you replace the 100a alternator with another mechman 250? with the two of them you will be fine also you can have him ship them to you (or tell you how) to bump the voltage to 15.3v output instead of 14.x. hit him up on a PM and he will get you headed in the right direction.
a couple of things make sure your alts are linked and are you trying to strap the amps and double check all your connections.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
It is at 15.3 already.
Each Alt has a 1/0 going to the Front Buss bar.
Amps are hooked to a Maxx Link, but not strapped, did that because subs share a common chamber..
Voltage totally goes to shit as soon as I touch the volume...
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
Posted (edited)
I will try just the regular master and slave option tonight on the amps and skip the maxx link.....
Edited by CR Boom
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
which channels on the maxx-link did you try should have been a &b positive and c &d positive if they were not strapped.
W/1 SUB & 2AMPs
Posted (edited)
Oh snap..... That is not how mine is.... I have a Y on the A+ going to one amp, and a Y on the A- going to the second amp.
Edited by CR Boom
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
can you get pics of batt bank? seems like what you said earlier, you're pulling from different points of the batt bank simultaneously, with 2 amps possibly choking the end from recieving current flow.
my first thoughts anyway
Scanning it in.. give me a few min,,,
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
Here is the Battery diagram,
Green is ground
Red is POS
Feed is the wires from the front
Amp is the wires to the amps
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
