sully Posted June 1, 2009 Report Posted June 1, 2009 Can you replace the 100a alternator with another mechman 250? with the two of them you will be fine also you can have him ship them to you (or tell you how) to bump the voltage to 15.3v output instead of 14.x. hit him up on a PM and he will get you headed in the right direction. Quote 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
oldschool Posted June 1, 2009 Report Posted June 1, 2009 a couple of things make sure your alts are linked and are you trying to strap the amps and double check all your connections. Quote TEAM GROUNDPOUNDERS INC. 156.5 OUT THE TRUNK OF A 95 CADDY W/1 SUB & 2AMPs score done on a termlab mic in the kick on the dash sealed was 154
emperorjj1 Posted June 1, 2009 Report Posted June 1, 2009 what do the amps do? go into protect? Quote J. JMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
CR Boom Posted June 1, 2009 Author Report Posted June 1, 2009 Can you replace the 100a alternator with another mechman 250? with the two of them you will be fine also you can have him ship them to you (or tell you how) to bump the voltage to 15.3v output instead of 14.x. hit him up on a PM and he will get you headed in the right direction. It is at 15.3 already. Each Alt has a 1/0 going to the Front Buss bar. Amps are hooked to a Maxx Link, but not strapped, did that because subs share a common chamber.. Voltage totally goes to shit as soon as I touch the volume... Quote 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's
CR Boom Posted June 1, 2009 Author Report Posted June 1, 2009 (edited) I will try just the regular master and slave option tonight on the amps and skip the maxx link..... Edited June 1, 2009 by CR Boom Quote 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's
oldschool Posted June 1, 2009 Report Posted June 1, 2009 which channels on the maxx-link did you try should have been a &b positive and c &d positive if they were not strapped. Quote TEAM GROUNDPOUNDERS INC. 156.5 OUT THE TRUNK OF A 95 CADDY W/1 SUB & 2AMPs score done on a termlab mic in the kick on the dash sealed was 154
CR Boom Posted June 1, 2009 Author Report Posted June 1, 2009 (edited) which channels on the maxx-link did you try should have been a &b positive and c &d positive if they were not strapped. Oh snap..... That is not how mine is.... I have a Y on the A+ going to one amp, and a Y on the A- going to the second amp. Edited June 1, 2009 by CR Boom Quote 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's
E a r t h Posted June 1, 2009 Report Posted June 1, 2009 can you get pics of batt bank? seems like what you said earlier, you're pulling from different points of the batt bank simultaneously, with 2 amps possibly choking the end from recieving current flow. my first thoughts anyway Quote
CR Boom Posted June 1, 2009 Author Report Posted June 1, 2009 can you get pics of batt bank? seems like what you said earlier, you're pulling from different points of the batt bank simultaneously, with 2 amps possibly choking the end from recieving current flow.my first thoughts anyway Scanning it in.. give me a few min,,, Quote 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's
CR Boom Posted June 1, 2009 Author Report Posted June 1, 2009 Here is the Battery diagram, Green is ground Red is POS Feed is the wires from the front Amp is the wires to the amps Quote 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's
