Would this be amp be tooled in a new "Sundown" case or are you going to use the case that it is in already?
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Posted Image
Nuff' said (or pictured for that matter) :)
Nice, looks like abit more then 4500 watts rms :)
It is close to 4500 at "12.8" volts.
I do box designs.
2 powers and grounds right?
i remember someone saying the 3500 was biggest single input you guys would be able to make.
1200 Sounds do-able.
any numbers being revealed?
sold everything
Yes, dual power and ground.
Testing so far:
I got 6900 @ 1.3 actual on 17.9v rest.
Did not measure voltage drop.
You can get close to 8k out of it with a rise closer to 1 ohm.
With a rise to 2.12 I still got 5290 out of it.
On 12v system:
3100 @ 1 ohm nominal with actual rise to 2.67 ohms (Drop to 13.6 volts)
4910 @ 1/4 ohm nominal with actual rise to 0.71 ohm (Drop to 11.6 volts)
I'll be doing more 12v testing to include 1/2 ohm nominal testing when I get my Jeep put back together (changing it over to 12v). The above was done on two Powermaster D3100s in Derrick's Explorer.
Resistive testing @ Factory = 5200 @ 14v @ 1 ohm
All clamp tests done a full ~6-7 seconds into the burp on my Extech Power clamp :
http://www.extech.com/instrument/products/...399/380976.html
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
wow
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
