you can just turn the gain down to 2000rms, if you have fully loaded SSD's, they should easily take 1000rms.
gain's not a volume knob, fyi
My electrical will be just dandy, if you read I ran two of these amps @ 1 ohm.
I just need a couple caps... :hairtrick:
I hope your not talking about capacitors..
2 SSA Xcon 18's
Sundown 2500D
Pioneer
4 Stinger SPV35 batts
SecondSkin Audio Damp Pro
Knukonceptz Flex[/size][/b]
i was scrolling down reading all the posts fast when i saw his post
"turn down the gains to 2000rms"
i did a double take on that. haha
:01nocomment8so:
TNCB
....my damn room was shaking, im like wtf is this how am i gonna die jakin off to vida guerra?
:01nocomment8so:
If you have the right equipment and know what you're doing it's entirely possible :)
10.x volts fo' life!
And then you just have to make sure you NEVER play a source that is strong/louder than the source material you used when setting that limit.
When someone has to ask a question like this, there is a 99.99% chance telling them to limit the amplifier output using the gain is NOT going to work.
You limit amplifier output by knowing the limits of your system and not letting your fingers roll the volume knob past that limit. . .
For subs - You could also look at the AA Havoc. A pair of them would be a nice match with that amp.
Brian
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
