Lights Pulsate, Noise When Car Is Running.
So here's what I have: 250 amp alternator with external regulator, big 3 done in 1/0. I have the regulator's ground right to the front battery, field of course to the field of the alternator, and ignition underneath my dash to the ignition switch ignition wire. As soon as my car is running, all of my lights pulsate. When I rev it, they pulsate faster. Of course I get tons of noise and it goes faster when I rev it when I have my system hooked up. Bad alternator?
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
What would that do? I have my alternator grounded to bare metal on the body of the car, as well as from the battery the negative connects to one of my transmission bolts, and then to my shock tower. Voltage is good, so it's not a voltage drop.
Edited by lanman31337
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
Where do you think it eventually goes? To the battery. IT IS GROUNDED, grounds are not the problem.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
Try hooking the ignition wire of the reg. to the battery, just to troubleshoot a little. I've had some ignition wires under the dash in my truck act really funny. If it works, just pick a new ignition wire, or use a relay and leave it hooked right to the battery.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
its newbs who have read somewhere about bad grounds causing noise and think thats all that it could be. Jeff whats your voltage sit at. Does it fluctuate? I'm curious but Im wondering if you are getting enough juice from that ignition wire or possible bad regulator.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Since I have an adjustable regulator, I turned it all the way down. It sits at 14.4. Doesn't move more than that. That's warmed up. If I turn it up to 15, it sits at 15. Lights pulsate/radio noise at any and all voltage levels.
PStone11 - good call. I'll give that a try when I get home. It could be some ignition noise. I have a fuse block that I ran into the car that has my solenoids for my doors and trunk hooked up, as well as the radio main power. I'll drop a fuse into my spare slot and hook up the regulator into that.
And also before anyone asks, I have the radio hooked up to the battery, same with the ground of it as well.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
You have to ground regulators? I have no ground wire or lug on mine, this could be why mine is doing the same thing?
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
My external has field, pos and neg. Neg goes to a good ground of course, field goes to the alternator, and pos goes to ignition.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
  • Who's Online   2 Members, 0 Anonymous, 1391 Guests (See full list)
