Any one have experience with this amp? I am looking into getting one. But the fact it doesn't come with a warranty is making me think twice.
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
great amps
no warranty due to what most people use them for...abuse
they are actually discontinued at this time for more improvements, but if you get a good price on one dont hesitate
Do you think my electrical will be able to hold one okay? (see sig)
*1) AudioQue 20k
My team mate has this amp and i think your electrical should be fine.. its a great amp and puts out great power.. he only has 2 group 31 batts and a 220A and we clamped it but he had mad voltage drop but it did about a lil over 2000rms at 1 ohm at about 10V maybe lol
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
2kw at 1 ohm???
I have seen a couple bench test like this.
"Battery only
3435w @ 4,60 Ohm (start volt 12,8v drop to 12,1v)
5631w @ 2,30 Ohm (start volt 12,8v drop to 11,8v)
8976w @ 1,15 Ohm (start volt 12,8v drop to 11,4v)
Battery + power supply
3805w @ 4,60 Ohm (start volt 14v drop to 12,9v)
6250w @ 2,30 Ohm (start volt 14v drop to 12,4v)
9550w @ 1,15 Ohm (start volt 14v drop to 11,9v)
So it's not to bad for one amp on a 12v system "
Edited by Bigg Boy
*1) AudioQue 20k
bump anyone
*1) AudioQue 20k
You should be fine, its designed to perform well on low voltage..ie 12.5 volts and up, nasty ass amps. Just be careful where you mount it, DD z series amps don't like vibration, therefore try not to mount it directly to your enclosure. The ddz1 first gen was notorious for the legs on the fets breaking off due to vibration. The design on the z2 and z2lv is a little stronger, so its harder for the fets to break, but it still happens..other than that they are pretty much bullet proof...go for it, you won't be disappointed!
supercharged hummer h2
8 Sundown nightshade v'2 Scott Bowman built 4th order bandpass
2 precision power pcx 4125(mids & hi's)
2 Stetsom 14k2e's
alpine ina-w910
dual Mike Singer350 amp alt
8 kinetic 2400 batteries two shuriken bt 120
1 kinetic 2000 under the hood
link to build log:
My link
I was going to "float it" off the back of my box which the back is 1.5" thick... but I'll see if i can find some where else
*1) AudioQue 20k
I like my z1 and plan on getting a z2 or 2
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
off the back should be fine, especially if its 1.5 inches thick, good luck
2 Stetsom 14k2e's
alpine ina-w910
link to build log:
My link
