BigJohnny Posted June 11, 2009 Report Share Posted June 11, 2009 So I have an idea of what I want to do now, and need to figure out how I'm going to do it, and more importantly make it symmetrical with the other side (two amp racks in the sidewalls) What material would I use to rough it out and get an idea of how it will fit, and furthermore, what materials would I use to build the final rack/frame? I was thinking of using some 1/2" square dowel or similar. Once it's in place I would be making a fiberglass cover, which is a whole other project altogether I need some advice here I've never done anything like this, and it's measuring stuff with the curves that get me. Is there anything I need to do to my trunk? should I clean anything out like the factory sound dampening stuff? Link to comment Share on other sites More sharing options...
BigJohnny Posted June 12, 2009 Author Report Share Posted June 12, 2009 I guess the square dowel would be fine.... Link to comment Share on other sites More sharing options...
pstone11 Posted June 12, 2009 Report Share Posted June 12, 2009 I usually just use 1/2" MDF for a base for the amps to mount to, then MDF Scrap to trim around the amps, then make the cover on top of that.. Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page! Link to comment Share on other sites More sharing options...
LHatt Posted June 12, 2009 Report Share Posted June 12, 2009 to get a idea of how it will fit you could just use Styrofoam and some epoxy to glue it together LHATT System: 2 mtx 4512's, 2 cubes each, tuned to 42hz http://www.youtube.com/user/angrymob7699 Link to comment Share on other sites More sharing options...
cthedinger Posted June 12, 2009 Report Share Posted June 12, 2009 you can really use anything you want you could even use the scraps if you had any from a box you built If you have any questions PM me or Add me on Facebook CLICK ME! Shop at ct-sounds.com Subscribe to us on YouTube Link to comment Share on other sites More sharing options...
BigJohnny Posted June 13, 2009 Author Report Share Posted June 13, 2009 I don't have anything left over from my boxes, I used that already I think I will probably go with the square dowel, and build the frame out of that, put a piece of plywood over it to mount the amp, and then build the rest of the frame work according to the trunk. I think I have a couple of places I can bolt it too. What do I do when I fiberglass it, I want the fiberglass, or the unit itself to be removable. how would I attach the cloth to the car body to glass it? I can't staple it into metal, and I don't think tape would hold it very tightly. Would I actually need to build some form of "box" to mount the frame to? Link to comment Share on other sites More sharing options...
cracker Posted June 13, 2009 Report Share Posted June 13, 2009 could somehow get creative with mounting some kind of vertical braces to the floor if you make that out of something thicker than the factory stuff. ive been kind of wondering myself but i found a place where the jack/toolbox was in my trunk. factory mounts and bolts FTW! but you could use some L brackets to make it stronger too. then make the rest around the mounts March 2010 SOTM winner my old buildhttp://www.stevemeadedesigns.com/board/topic/50219-dank-aka-crackers-bonne-new-v2-build-in-the-works-hahahaaaaaa/page__hl__crackers my youtube page - http://www.youtube.com/profile?user=jackiedan04#g/u my feedback - http://www.stevemeadedesigns.com/board/topic/56540-official-cracker-feedback/ i need tacos and bass to live!!!!! and will NEVER change hahaaaa TEAM NOIZE VIOLATION Link to comment Share on other sites More sharing options...
