Box Build Need Some Help.
Ok need some help.
Max dimensions are 42 wide 10 tall and 12 deep. So 2.1^3 feet gross.
Ported I wanna do external ports through the rear deck. I can do 1 4" round port for 39^2 inches of port area. at two cubes i need like 32^2 inches so that works out.
Calculating frequency though, all my programs and the12volts calculator does it for internal port.
Any help?
how far up is your rear deck and what freq do you want how many ports just one 4in will it be flared answer these and i might be able to help
Edited by Jville140db
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
so if you want to do those dimensions you would need at least an 8in port to get into the 30's and that would be 38hz if you only have the 5in to work with you will end up with about 44hz hope that helps
Currently in car
isnt a 4 inch port like only like 12.56 sq inches
so youd would need like 2 or 3 of these ports.
or you can probably get away with 1 6 inch
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
22.5 in tall so its 90 inches of port area which per ^3 foot for my sub is 12in-16in so its about right? I think? wth idk I am in no condition to be making these decisions right now
port area people normally refer to doesnt even matter what the length is.
1 4 inch port is 12 sq inches
2 cubes should get around 30 sq inches.
port volume matters with the sq inches x port length
Edited by tibs
8 - Re SE 12"s
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
  • Who's Online   1 Member, 0 Anonymous, 1731 Guests (See full list)
