you'll need a pickle fork or aka tie rod seperator to break it free from the knuckle.
if it has a jam nut or sleave with a bolt(s) loosen them up, but before you try removing the tie
rod measure or count the amount of threads showing on the rod itself. you'll need to know that
for when you put the new one's on,so you can get it close within speck. you'll need an alignment
afterwards.
center console: lvl 4 12 1.75 cu ft tuned 37htz
alpine cda-9886
dc audio 120.4
infinity kappa 6.5" components
I wouldn't use a pickle fork to loosen it because they almost always tear the grease boot. Smack the tie rod end or knuckle with a big hammer and it should pop loose while being careful to stay clear of the boot. Before I loosen the nut I put white out on the threads so I put it about the same spot when you put the new one on. LIke he said, loosen nut or sleeve and the end should just screw off.
this is in the wrong section however vigilant is right.
edit: wrong person
Edited by B slaps yo mama
I Rock 4 Doors 4 More Whores!
SMD SUPER SELLER
my seller feedback http://www.stevemead...-mama-feedback/
more seller feedback http://www.stevemead...-slaps-yo-mama/
x2 its not bad at all and if it dont budge(tie rod/ lock nut) then put heat on it/ torch
  • Who's Online   0 Members, 0 Anonymous, 616 Guests (See full list)
