i got a new belt awhile ago an it started squeaking again, is there a easy way to fix it? i got some of that belt dressing but it says not to use on serpentine belts...?
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
Squeal? Usually caused by it slipping, belt dressing worked for me though. Only time it squeals is on start up when the back side of the belt would rub the idler pulley though. Replacing the belt actually solved my problem though. It all started after the tensioner broke though
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
its not a squeal its a squeak
Sure it is not your idler pulley or tensioner pulley? Those should be replaced regularly. The bearings will go bad in them and cause a squeaking noise
The woofers might suck all the air out your lungs
(if you stand too close)
When the monster hums
x2, and belt dressing will cause the squeak to get worse, i learned the hard way
1997 S10 EC
Whats in it
106.9 Sq.ft. Hushmat
DB Elec. 250 amp alt.
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
poopy Alpine door co-ax's
Change IS Coming
Take a bar of soap and with the engine running ease the soap on the underside of the belt.
2000 Trans Am ws6 - 6spd / M9 / cam / full bolt-ons / semi full suspension / tune
1998 Integra - daily beater, [2] AB XFL-1244's / 4ft³@35Hz, 61in² / Saz-3500dv1 @.85Ω
  • 1 month later...
for real?
Eclipse cd7000
Take the belt off and clean it using an old toothbrush and warm water with MILD amounts of soap. Do not put soap directly on the back of the belt as this can cause the belt to start slipping (especially if the belt is on the vehicle and running). Allow it to air dry for 24 to 48 hours. Make sure it is completely dry before you put it back on.
Edited by 1992Chevy
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
What he said^
I would replace your tesioner too. Its cheap and easy to do since your taking the belt off anyways.
