Mach 5 Mj-18m
So i have a big room (800+ sf) and right now i have a 12" cvr in a slot port box, well needless to say the room is a little to big for this 1 12. so im going to be getting a mach 5 mj-18m when mark gets his magnitizer working again (hopefully soon). now i want to build a box that will have a loud flat response from 15hz-120ish hz. so im reaching out to you guys here, what type of box would suit me best: a slot ported box, a folded horn, a bandpass of some type, a t-line, or just a solid built sealed box?
Specs
T/S Parameters
Fs = 24 Hz
Re = 3.6 Ohms
Qes = 0.37
Qms = 5.59
Qts = 0.36
Mms = 316.6 g
Rms = 8.5 kg/s
Cms = 0.14 mm/N
VAS = 210 litres
Sd = 1029.2 cm2
BL = 21.3
Xmax = 15 mm
Power Handling - 700 watts
Sensitivity - 94.2db (2.83 volts)
Impedance - 4 Ohm (SVC)
Recommended Box Sizes
Sealed - 93 litres (3.3 cu. ft.)
Ported - 142 litres (5 cu. ft.) 30Hz tuning
EBS - 283 litres (10 cu. ft.) 18Hz tuning
Eric
head unit - Panasonic MXE CQ-C7403U
amp - Cerwin-Vega EXL 1200D
subs - (x2) Cerwin Vega V-MAX 15.4
box - 5.8 ^3 at 32hz
spkrs- Phoenix Gold Rsd Comps
No opinions? im thinking just do a rock solid box sealed up, but if any other box will work better?
ebs is extended bass shelf correct?
what is the difference between this and a ported box? 10cf box is huge haha
maybe a t-line?
mine plays anything above tuning great and will play below tuning just loses some output
tuning is 34hz btw.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
The Fs for this sub is 24hz, would building a t-line tuned to 30hz work well? I though for t-lines to perform their best they should be tuned to the drivers Fs?
  • 1 month later...
In a home theater, I would only care for everything under 80hz or even lower.
I got a MJ-18M in 11 cubes net tuned to 20hz off about 650watts from a behringer 1500 amp. I think I have it lowpassed at 80hz. I can hear and feel everything. Really loud on music too. War of the Worlds FTW. :D
SPL-Lab REPCar: 1996 Honda Accord F22B1 CoupeSuspension: Megan Racing Full Street Coilover Dampener KitAlternator: DC Power XP 270Batteries: XS Power D5100 & D3100Wiring: KnuKonceptz & 2/0 Welding cableHeadunit: Kenwood KDC-MP642UComponents: Hybrid Audio ClarusAmplifers: Lanzar OPTI250X4Subwoofer: 2 Sundown Audio E8.v2Deadener: Sound Deadener ShowdownSPL Meter: SPL-Lab RTA Pro meterWant an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.CA ref: (enellz, 92c1v1c, el_chupo_, Thixx, Kraudio12, SethPhillips, NJack2AF, JamesKarr, ExpoSport, 01 S 10, wgsj_fortvalley, fast306stang, Lakota, blackga, TheLow, adrian1185, the727kid, rudy, sundownz, lmllopez, traksta15, gentlejax, satchel50207, Bigthangs, Goindef154)CACO ref: (extremechevyman67, ghostmechanic, FatBoy2, TheMan007, bdufner, 350zkid, ironb, bmansbach)SSA ref as phi: ( shizzzon, porkchop, onebadmonte, stevemead, TRP, ///M5, denim)SMD ref: (DC Power Rob, Nathan@XSPOWER, Jman08)And then some.
You could do a tline, but it would be huge.
Tline's have tight and accurate bass.
Mine is tuned to 26hz, and it loves everything lower then 30hz.(i have watched transformers on it, and i could feel everything ! )
Man to 15 to 120 flat is a big ask. Especially if you want it loud.
Either a huge ported box or an exotic box like a horn or very very long t-line is what you need.
10.x volts fo' life!
