multi subs 4 or more subs..... post them up
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
4-Kicker compVR 12's (2005-current)
Member builds section:
http://www.stevemeadedesigns.com/board/ind...?showtopic=3161
My 1997 Integra.
Also in the Videos section and Feb and March SOTM nomination threads.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
ok we knwo wos this is, for those who don't, ho problems..... now is it a sealed setup or a 4th order bp
Edited by SPLGEO
What would a 4th order BP setup look like or How is it constructed? Is it anyway better than a standard BP?
THE GRADUATE 10:18:2007
4th order bandpasses or selas chamber firing into a ported on, "normal bp" it call it... pornstar has a 4th order band pass.. they start to not look like bp when theyget bigger
Got any links to some sites? How orders are there for Bandpasses?
his looks to be sealed-no visible ports....a 4th order can be port on either side of the woofer so cone side or basket/mag side-also called single reflex bandpass (your usual pre fabs w/ the plexi window) a sixth order is ported on BOTH sides of the sub/s so cone side and mag side also called dual reflex BP, 8th order I BELIEVE (correct me here if u can) would be like a sealed box firing into a LOADING chamber (essentially a bigger/open area but still contained by "box" walls) usually sub firing sideways into that area and then the side of that area open forward or rearward like a "mouth" I saw a drawing on this of one I think I'll find it again if I can.
OK-L-A-Z-Y Bastages....
http://www.diysubwoofers.org/talkshop/messages/33907.htm
..."A parallel-type 6th-order box with both of its ports firing into a third vented box is an 8th-order band-pass enclosure".
PIC courtesy of not me....
http://www.geocities.com/f4ier/subsim8BP1.htm
Edited by LSN2meBoom916
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
