Project "SQL Monte Carlo v4" *Updated 1.26.12*
looks great! hurry up and get this thing runnin, i want a demo!
Don't have high expectations, it's not gonna hit anywhere near as hard as your system. I just hope it sounds clean, that's my only need.
Cool I love the dash kit. Was that custom made? Keep it up.
Yeah, it's custom, but you can customize one of your own and order it from www.humount.com
I see you have a Monte too, got a system in it? Let's see what you're workin' with!
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
I wish they had a mount for my truck. Time to attempt to make my own i guess.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
they do unless you have a front end swap
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
I do, its a 94' :)
Current System:
Pioneer 6900 HU
Bass:
That hu kit is badass you should get a pick with it lit up.
x2....yep!
2006 Nissan Titan Crew Cab
XS Power D6500 up front, Mechman 270 amp alt,
Front Stage:Hybrid Audio Legatia Tweeters and Midrange drivers in Custom A Pillars, HA Unity 6x9 inch Midbass in the doors, powered by an Arc Audio 1200.6 X2 and connected to a JL TWK 88 DSP
Subwoofers: Four 8 inch Soundqubed Subs in a ported enclosure. Incriminator Audio 20.1 on the subs (@ 1ohm)
Performance: JBA Headers, Uprev Tuned, Dynomax bullet muffler, 3 inch exhaust all the way back. Air raid CAI.
Wheels: 18 inch Balistic Jester wheels on 33 inch Nitto TG2's
Suspension: 6 inches of lift total. DK UCA's, DK LCA's, Icon coilovers up front, Bilstein Shocks in the rear with 4 inch blocks
2007 Chevy Suburban LTZ
Engine: 5.3 DOD Delete, BTR Stage 4 truck Cam, TSP Headers, Gibson Catback exhaust. Tuned by Sam @ Advanced Modern Performance.
Suspension: 2/4 Belkin drop. Belkin Sway bars, Spohn Panhard bar
Audio: Pioneer 8400 NEX Head unit, Audio Dynamics DSP, 6th order enclosure with three 10 inch DC Audio Level 4s behind the third row. Wolfram 4500 on Subs, Wolfram AW 250.4 on the front stage Dual SkyHigh Car Audio 8 inch mid bass in the doors, quad 3.5 inch midrange drivers in the A-Pillars
Dual Alternators, Mechman 320 powering a CES 40ah Lithium battery, OEM alt has an AGM on it.Viper remote start.
Wheels:  24 inch Luxx wheels/ 305/40 R24
Grammatically speaking, Prolly is not a word.
x2....yep!
There's one that show it lit up on the first page
Alright, got some more work done yesterday...
When I installed the comps I had a pretty big gap, I don\'t think it would have been an issue since the cone wasn\'t visible from the gap, but I decided to fix it anyway
Posted Image
Posted Image
Posted Image
I decided the best way to fix this would be to seal the speaker in with non-hardening modeling clay. I sealed it up all the way around to prevent the possibility of any leaks. Since i\'m gonna be running fronts only (no rear fill) I figured this is necessary to make the front stage as strong as possible.
Posted Image
Posted Image
Posted Image
After I finished sealing both mids, I applied some RTV Silicone sealant along the back side of the pod so I got a good seal once the pod was put back in the door.
Posted Image
I had to let the RTV setup for about 15 minutes so it wasn\'t just a gooey mess, especially since I was going to solder the speaker wire connetions. So while that was setting up, I decided to strip the speaker wire leads and tin the wires.
Posted Image
The one set of speaker wire is stripped long like that so I could twist it together w/the tweeter wire so it looks like a twist (like the donut) and then solder it nicely.
Posted Image
I also tinned the connectors on the mids
Posted Image
After the RTV was semi-solid, I soldered up the speaker wire connections and reinstalled the speaker pods into the door panels. If you look closely you can see a little gap between the speaker pod and the door.
Posted Image
Posted Image
Posted Image
So I had to handle the gap
Posted Image
Posted Image
Door panels back on, finally.
Posted Image
Posted Image
I was going to run my power lead, RCA's and remote lead this evening, but didn't quite work out like that. When I got ready to leave work, I went out to my car to start it up and get the A/C going and then was gonna go back in and grab my tools. When I got to the car I noticed my back tire was nearly flat. I had a nail in it over the weekend and got it plugged up but apparently the plug was leaking. So I was buggin' out about that and forgot to get my tools. Kind of a blessing in disguise cause my order from Darvex should be here Thursday so I'll just do it then, and can get my Stinger digital voltage guage wired in and installed at the same time.
Looking good brotha. So the question is, are you gonna bring that car out this weekend to Santa Rosa. There is an SQ show this weekend and by the looks of it your on the right track. If not come on out just to see some other SQ guys. I'm a rookie in this SQ stuff but, definately appreciate the hard work and dedication.
  • Who's Online   0 Members, 0 Anonymous, 3117 Guests (See full list)
