Luda Posted June 17, 2009 Report Posted June 17, 2009 Looking for a new Amp for my Type R for the upcoming MECA competition. The sub is DVC wired to 2 ohms nominal, looking for 700-1000W. The sub is in my DD so i want a amp that can run for extended periods of time, and of course crank out solid numbers on the meter. Im currently running a Hifonics NX400 that i had laying around from an old install, its rated @ 320W @ 4ohms, and supposedly isnt 2 ohm stable, but i havent had an issue other then after about 15-20 minutes the amp is so hot you cant touch it. My two current choices are: Power Acoustik LFA2000D and the Hifonics BXI1208D, both of which are rated @ 900Wx1 @ 2ohms my price range is about 200$, so if you all have any other amps that fit the bill id love to hear about them. 2005 Grand PrixSource: StockFronts: Stock 6.5 ComponentsRears: Stock 6x9Subwoofer: FI BTL 12" Fully optionedSubwoofer amplifier: Kenwood KAC-7203 bridged @ 4ΩEnclosure: 3.41cuft tuned to 33hz
Jville140db Posted June 18, 2009 Report Posted June 18, 2009 Looking for a new Amp for my Type R for the upcoming MECA competition. The sub is DVC wired to 2 ohms nominal, looking for 700-1000W. The sub is in my DD so i want a amp that can run for extended periods of time, and of course crank out solid numbers on the meter. Im currently running a Hifonics NX400 that i had laying around from an old install, its rated @ 320W @ 4ohms, and supposedly isnt 2 ohm stable, but i havent had an issue other then after about 15-20 minutes the amp is so hot you cant touch it. My two current choices are: Power Acoustik LFA2000D and the Hifonics BXI1208D, both of which are rated @ 900Wx1 @ 2ohms my price range is about 200$, so if you all have any other amps that fit the bill id love to hear about them. is a type r 12 and you want to put 700 to 1000 rms for it the subs only rated for 500 ive seen it take 600 maybe 700 if you wanna use one of those amps though i'd go with the hifonics proven power output Car is 2010 Scion Tc Currently in car Deck- Sony XAV-60 in-dash mobile video system Speakers- Rockford Punch 6.5in comps in the front and coax in the rear Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service Wiring- all rockford nuff said Enclosure- Dual 12in custom box by SRQ Battery- Optima Yellow top with big 3 done Sound Damping- All Dynamat products 1-2 layers throughout with liner on top Link to my build log- http://down4sound.co...=newpost&t=5275 Link to my youtube- http://www.youtube.c...ser/Jville140db MECP Advanced CEA # 110531 BassBox 6 Pro for Box Building/Re audio box calculator If you can hear the passenger it aint loud enough!!!!!!! QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
Luda Posted June 19, 2009 Author Report Posted June 19, 2009 is a type r 12 and you want to put 700 to 1000 rms for it the subs only rated for 500 ive seen it take 600 maybe 700 if you wanna use one of those amps though i'd go with the hifonics proven power output ive run 850WRMS to a pair of them daily without an issues, and for burbs/short runs ive seen over 1KW, im more worried about getting a solid RMS output from the amp vs how much power the sub can take 2005 Grand PrixSource: StockFronts: Stock 6.5 ComponentsRears: Stock 6x9Subwoofer: FI BTL 12" Fully optionedSubwoofer amplifier: Kenwood KAC-7203 bridged @ 4ΩEnclosure: 3.41cuft tuned to 33hz
Rogers Posted June 19, 2009 Report Posted June 19, 2009 ive heard of them being pounded at 1100rms daily.... obviously not reccomended..... the type r is a beefy sub... i had one running on 600rms dialy and had no problems.... i think 700rms would be fine as long as the signal isnt clipped and your not playing frequencys below 30hz.... plus it never hurts to have some extra power on hand... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
AI James Posted June 19, 2009 Report Posted June 19, 2009 if you want proven power output stay away form hifonics. the diablo 1k at 2ohms would be great for that power, as well as many many other amps that are actually decent amps for the money
cunokyle Posted June 20, 2009 Report Posted June 20, 2009 My two current choices are:Power Acoustik LFA2000D and the Hifonics BXI1208D, both of which are rated @ 900Wx1 @ 2ohms I'd go with the Hifonics. The woofers might suck all the air out your lungs (if you stand too close) When the monster hums
