Amp Wiring Question
SojiaRaggs9000
I currently have 2 12" DC lvl4 XL D2 coil subs running on a RF T1k (power elite series) Any ways I ordered a DC PAI 3000.1 amp. WHen I go to wire it up what would be the best way?
1) Wire them down to 1 ohm (each speaker separately) and have 2 sets of wires running to the amp??
or
2) Wire them together @ 2 ohm and run one set of wires to the amp??
or
3) Wire them together @ 2 ohm and run them bridged??
Also not sure if these are correct but its what I found on the net.
PAI 3000.1
rms power, 1ohm mono - 3000w x 1ch
rms power, 2ohm mono - 1500w x 1ch
rms power, 4ohm mono - 750w x 1ch
rms power, 2ohm linked - 5400w x 1ch
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Just run them separately.
Eclipse cd7000
  • 3 weeks later...
could only do this is the amp is .5 ohm stable
i'd say this would be your best and safe bet of doing it, just my .02
its a mono block amp not a 2 channel amp so you could only bridged them if you had 2 of the amps strapped
just my 2 cents on it
or
or
PAI 3000.1
You can only get a 2ohm load or a 0.5ohm load final at the amp.
Series each woofer, than parallel those two pos and neg leads to the amp.
The double outputs on the amplifier are internally bridged, if you parallel each woofer to each output, you'll end up with a 0.5ohm final load.
It's a Zenon amp so it'd take it decently, but if you're rolling a stock charging system, I'd highly not reccomend it.
Whats up TCCA buddy, If I were you, I would wire them in series with each other, then parallel to the amplifier.
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
