cvxsmitty58 Posted June 25, 2009 Report Posted June 25, 2009 currently i am running 1 power acoustik 2600 (i know its shitty but hey i just graduated from h.s. and i aint soberbills) to 2 kicker cvx 12's. I absolutely know that the amp is not putting out what it says it will (550 rms x2 at 2ohms). So i figured i might pick up another one since there only like $180 bucks new and relatively loud. All in all i have 3 questions. 1)How much do you think the amp is actually putting out knowing that i still have a stock alt (jeep grand cherokee), no big 3 done and no extra batts? 2)Will 2 be too much for the cvx's to handle (rated at 750 rms)? 3)If i do the big 3, will that be enough or should i be looking into getting extra batts? If so what is a good batt for my need Any comments are appreciated Thanks
hotshot27 Posted June 25, 2009 Report Posted June 25, 2009 Def an extra battery, possibly a bigger alt for a 1500 rms setup. big three is a must. like right now, before you sleep lol. CVX will take a good clean 750, just be sure to know if they start to smell a little, give them a rest. Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN
Boon Posted June 25, 2009 Report Posted June 25, 2009 Def an extra battery, possibly a bigger alt for a 1500 rms setup. big three is a must. like right now, before you sleep lol. CVX will take a good clean 750, just be sure to know if they start to smell a little, give them a rest. Uh, what? I've run several 4kw systems off 1 good battery and a stock alt. 1500wrms is tiny. Upgrade the battery and do the big 3 and you'll be fine. 10.x volts fo' life!
BigJohnny Posted June 25, 2009 Report Posted June 25, 2009 There is some math in this thread that will give you an idea of how much your amp might really be putting out http://www.the12volt.com/installbay/forum_...~TID~75836~PN~1
cvxsmitty58 Posted June 26, 2009 Author Report Posted June 26, 2009 thanks for the input yall.....i have a gold top right now.....should i upgrade to an even higher level battery?
benz280se Posted June 30, 2009 Report Posted June 30, 2009 currently i am running 1 power acoustik 2600 (i know its shitty but hey i just graduated from h.s. and i aint soberbills) to 2 kicker cvx 12's. I absolutely know that the amp is not putting out what it says it will (550 rms x2 at 2ohms). So i figured i might pick up another one since there only like $180 bucks new and relatively loud. All in all i have 3 questions.1)How much do you think the amp is actually putting out knowing that i still have a stock alt (jeep grand cherokee), no big 3 done and no extra batts? 2)Will 2 be too much for the cvx's to handle (rated at 750 rms)? 3)If i do the big 3, will that be enough or should i be looking into getting extra batts? If so what is a good batt for my need Any comments are appreciated Thanks if you are gonna pay 180 for another crappy amp just to get close to 1000watts why not just save a few more dollars ( 69 to be exact) and get an audioque 1200 and actually get the power your'e payin for? they are 249 shipped and they have great customer service.
