Team_DC-Derrick Posted June 25, 2009 Report Posted June 25, 2009 * 550W x 2 Channel Max. Power Output at 4Stereo * 370W x 2 Channel 0.1% THD at 4Stereo, 20-20,[email protected] (RMS Continuous Power) * ChannelFlex Crossover Adjustable Low-Pass Crossover (12dB/octave, 50-200Hz) Adjustable Pre-Out High-Pass Crossover (12dB/octave, 50-200Hz) * Subsonic Filter (0-60Hz) * Free-Flow Signal Circuit * Double-Sided PCB * High-Current, High-Speed Output Devices * High-Efficiency, High-Energy MOS-FET Power Supply * Audiophile Grade Component Selection * Intelligent 7-Way Discrete Protection Circuitry * Music Reproduction with Low Distortion & Ultra-Low Negative Feedback * Efficient Cooling with Low-Profile Heatsink * Multi-Mode Configuration * Stereo/Mono Switch i dunno, it says it does, but i guess you just mess with it till it sounds really good to you... The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
Guest Posted June 25, 2009 Report Posted June 25, 2009 i have no idea... it doesnt say anything but subsonic and its a switch thats either on 12 db or 24 db doesnt have a negative sign on either of the two... huh....try playing a 20hz tone not very loud, and flip the switch from 12 to 24 and back and see if theres a difference in the cone movement. if there is, keep it on the one that makes the sub move the least edit: i found "Subsonic Filter (10Hz Fix)" http://www.caraudioforum.com/vbb3/showthread.php?t=179853
ps6435 Posted June 25, 2009 Author Report Posted June 25, 2009 huh....try playing a 20hz tone not very loud, and flip the switch from 12 to 24 and back and see if theres a difference in the cone movement. if there is, keep it on the one that makes the sub move the least edit: i found "Subsonic Filter (10Hz Fix)" http://www.caraudioforum.com/vbb3/showthread.php?t=179853 the only dials on the amp are the gain dial and a low pass switch that goes on or off then a dial to where to tune the low pass to the only choice for subsonic is 12db or 24db just looked at amp
ps6435 Posted June 25, 2009 Author Report Posted June 25, 2009 the only dials on the amp are the gain dial and a low pass switch that goes on or off then a dial to where to tune the low pass to the only choice for subsonic is 12db or 24db just looked at amp im going to rewire amp first... then i will try the song with lower bass and see how it sounds...
Guest Posted June 25, 2009 Report Posted June 25, 2009 a 10hz subsonic filter is really pointless imo...who plays tones that low?
Guest Posted June 25, 2009 Report Posted June 25, 2009 im going to rewire amp first... then i will try the song with lower bass and see how it sounds... make sure to re-tune the gains
ps6435 Posted June 25, 2009 Author Report Posted June 25, 2009 make sure to re-tune the gains i will... but do u think theres a way i can just pop out the port i got now then figure out how to tune it then put a new port in? i got the box wood glued together... there a way to take it apart?
Guest Posted June 25, 2009 Report Posted June 25, 2009 i will... but do u think theres a way i can just pop out the port i got now then figure out how to tune it then put a new port in? i got the box wood glued together... there a way to take it apart? its just best to make a whole new box, plus i dont think you can take the box apart w/o tearing or cracking the mdf
ps6435 Posted June 25, 2009 Author Report Posted June 25, 2009 its just best to make a whole new box, plus i dont think you can take the box apart w/o tearing or cracking the mdf i kinda wish i didnt have to pay anyone but 15-25 dollars for a scetch would be worth it i guess...
Guest Posted June 25, 2009 Report Posted June 25, 2009 i kinda wish i didnt have to pay anyone but 15-25 dollars for a scetch would be worth it i guess... its way worth it.
