so i wanna use brass bolts or brass screws or w/e brass i can find to use as terminals to avoid runing a long speaker wire through the port of the new box im going to build tomorrow. whats a good way to keep the wire thats inside the box from coming off the bolt? i was thinking maybe sliding on two nuts and wrapping the wire around the bolt between the nuts and then tighten the nuts together then put some glue or something on the outter side of each nut to keep them from moving on the bolt. does that sound like a good idea or do u guys have any better suggestions?
ring terminals, I always use the 1/4-20 bolts about 1.5" long, lots of brass washers, brass nuts, works great
very low resistance electrically
ring terminals are the things u crimp around the wire and it kind of extends into a ring, right?
Usually in my experience they seal themselves. You could probably seal them with resin or caulk, but that could end up with really messy threads on the bolt. Bolts are really easy to use as long as you use them with ring terminals.
Ring terminals look like this:5Copper-Ring-Terminals-for-.jpg
Make sure if you are using 1/4 inch bolts that you drill a 1/4 inch hole, even a 1/16 of a inch smaller is okay as long as the bolt is snug so there is no air leak.
anyone know where i could get ring terminals for 12 awg? and does it really matter what metal the terminal is made of? if so what are the ones to look for?
  • Who's Online   0 Members, 0 Anonymous, 8734 Guests (See full list)
