1976 f100 blowthrough. 4 15's in. 2 AP 3k's, SBN 2012 updates!
I can't wait to see this, gonna be another month or so before I can start building mine..
I can't help but notice in this pic the port sides that are along the back wall, the right one is screwed to the end of the main port piece and the left one is screwed to the side of the main port piece.. It looks like they are the same size and that would throw the left one at 3/4" longer than the right one which it looks like. I would measure those dimensions again.. It may be an illusion and you mightve cut that one 3/4 less, its just something I noticed.. Also the port width along the back wall needs to be half of the main port width..
Unless there is some science going on here that I dont know about then by all means please disregard.. Just would hate to see this much work get bad results because of some simple things that were looked over.
Keep it up!
Keep it up!
lol ive been waiting for someone to say this. The last piece on the right that is the port, I cut to short so I screwed the second piece to the back instead of on to the side. It evened out so both sides are the same depth. you are right that one side is longer horizontaly than the other. the longer side on the left isnt glued, I just screwd it in to make sure it matches the height as all of the other pieces. I wasnt aware that it needed to be half of the port, that is honestly the first time i have heard that lol. my previous boxes have given me good results with this way, so I didnt change it you know. so far it is looking promising. if I need to I can crawl into the box and shrink the rear of the port lol.
thank you very much for the info. instead of just keeping it to your self drinks.gif
MY TRUCK BUILD - 1976 F-100 Ranger. Fully built 482 big block, 4 DC lvl4 15's in a blowthrough, plenty of custom fabrication.
MY HATCH BUILD - 1993 Honda Civic DX Hatchback . Clean daily driver, dropped, subtle customization.
oooooooooooooooooooooooo Ford... luv!
haha thanks
No problem, can't wait to see it finished!
yea i cant wait either lol
ok old box is out. and the new is in. the low notes are insane, I cant wait to see what all four 15's can do.
Blocked off the first two sub holes.
today was a test fit to make sure everything fit. all went well. after N8 had advised that i do a second layer, I was worried about flexxing, but all seems to be good. I will see for sure when i get the other 2 15's. I have plenty of room to get inside and do a second baffle if need be. over all i am very pleased with how this came out.
looks good, cant wait to see the other two in there, you might need to brace the back wall, it might flex a little bit :D
Edit: back wall of the cab that is.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
lol most definitely
  • Who's Online   0 Members, 0 Anonymous, 1666 Guests (See full list)
