ok.. when i start the car the idles real high and won't idle down until i pump some gas "maybe this is normal.. maybe not idk.."
when i start driving "especially from stop".. it starts to lose power and almost shuts off and kinda starts shaking & kick'n... "sometimes it does shut off.. then it rolls :blink: " <-- whats up with that ?
and to top it off...
while in D "drive" the car shakes...over time it shakes more... "as if the belt was slipping... which it ain't" <-- i was thinkin maybe the fuel filter... its be... oh... like over 28 years since its been replaced.. *good idea or not really?*
now... i already replaced all the plugs, cap, coil, etc. "tune up" so i know it cannot be that... i was thinkin it was the catalytic converter "yes my car has one.." my mechanic friend said after awile they get full or shit and then must be replaced...
ALSO ! i noticed there is this black shit coming out of my exhaust... i think its soot.. but i ain't not mechanic guru..
Well thanks ok bye.. :lol:
i dont think that car will have a knock sensor. I would clean out or replace the fueling system anyways, even if that doesnt fix the problem. It will save you down the line
then im rambo bitch
What model vehicle you have?? I would say Replace fuel filter for sure...Does the vehicle have a carb or is it fuel injected?? Sounds to me like this baby just needs to be cleaned out real good...Have you ever heard of Sea Foam?? I would run it through my Intake manifold and let it clean some stuff out... As far as the car shaking in Drive..That could be a number of things..First clean that baby out...
it has a carb "which i replaced about 2 months ago" and whats sea foam and where do i put it ? i used a sludge cleaner when i changed my oil and it busted my oil pump...
and whats a knock sensor ? :blink:
its a 1979 cadillac coupe deville... 425 v8.. 4 barrel carb.
dEFINATELY REPLACE THE FUEL FILTER, ALSO HAVE YOUR TANK FLUSHED DOG, JUST DID THAT TO THE G.F.'S MOMS TRUCK (94 f/s chevy) AND IT RUNS 100%BETTER!
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
how much u think it cost ? i can get the part for the $75.. but i'm not that advanced in the fuel area... and the local shop charger $50 and hour "thats with my pimp discount"... u think it would be about $175 ?
sOUNDS ABOUT RIGHT, HER FILTER WAS UNDER THE TRUCK ALONG THE FUEL RAIL THOUGH....SO i CANNOT BE TOO CERTAIN.
f'in caps lock...
Edited by roscoe1129
Scientia est Vox
