Are there any other "side effects" to using a smaller enclosure besides needing more power?
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
Anybody?
Too small of an enclosure could damage your woofer.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
how can a small enclosure damage a woofer?
small enclosures usually are peakier in the notes that they play, meaning that some notes are much louder than others. and small enclosures makes the woofer need more power to get the same output as if it was in a larger enclosure.
Edited by Krannyman92
You will get more box rise...
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
If it's too small of an enclosure, the backpressure of the air behind the woofer could cause mechanical damage.
Box rise is a factor, and also the smaller the enclosure the higher the frequency of the tune. In order to get a lower frequency, mass needs to be added to the cone of the woofer.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
Not sure about this^^^ might be right?
This is correct^^^.
I do box designs.
Hope I dont sound like an idiot here but what do you mean by adding mass to the cone of the woofer?
Edited by Basshead08
Added weight to a cone lowers the Fs of a sub...( the freq.)
I do box designs.
Its probly better that you don't know!
There isn't any reason to manipulate a manufactures speaker.
Adding mass means to glue stuff to the cone to make it heavier and can also damage a woofer very quickly if you don't know what you are doing.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
  • Who's Online   0 Members, 0 Anonymous, 549 Guests (See full list)
